Old 09-02-2005, 05:21 AM   #3781
BrainTeased's Avatar
Originally Posted by uaerc
Andy T
Thanks for the clarification. what part do they play...... does it have anythnigg to do with traxtion.. ? i mean if my shock setting is on the outter hole toward the wheel the shock is more vertical what will it do... ?? hightraction or low.......... and vice versa ?
the more vertical the shocks are the more stiffer the suspension will become. this ussually gives you less traction as your limiting the weight transfer to that particular side.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-02-2005, 10:33 AM   #3782
ziggy12345's Avatar
I need a new chassis for the RRR. has anybody any comments on the different ones available compared to the kit supplied ones.
The Skyline one looks nice but its made from material 2/1/2 times stronger than the original so would expect it to be too stiff.
Kyosho also do a 7075-T6 version and what about the 4mm one?
Any comments anybody?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 09-02-2005, 10:55 AM   #3783
jeffreylin's Avatar
R/C Tech Charter Subscriber
Cheers
The Skyline one should be made of the same material as the stock one. People who uses it tells me that there is virtually no difference.
Kyosho makes 2 chassis for the RRR, the stock one and another without the battery plate opening and in the bronze color. They are identical in thickness and material otherwise. I tried it and I feel that it made the car push a little.
jeffreylin is offline   Reply With Quote
Old 09-02-2005, 01:05 PM   #3784
ziggy12345's Avatar
The skyline one is made from 7075-T6 Aluminium. The stock from 615 There is a difference in tensile strengh. The 7075 is around 83K psi and the 615 around 30K Psi
The Kyosho one without the battery plate is also 7075 so i can assume any thicker or stiffer chassis plate will make the car push a little
I would like to soften the front but get too much steering so might try a stiffer chassis. The skyline one looks like the best bet
Cheers
Sponsored by:
Norfolk and Chance
Old 09-02-2005, 01:17 PM   #3785
jeffreylin's Avatar
Cheers
The stock one is 7075 as well.
Old 09-02-2005, 04:58 PM   #3786
I know that 3Racing makes a 4mm chassis. Anyone tried? thx.
silverM3 is offline   Reply With Quote
Old 09-02-2005, 05:05 PM   #3787
jeffreylin's Avatar
Too stiff, really makes the car push.
Old 09-02-2005, 05:55 PM   #3788
AndyT 's Avatar
Andy T
With the shocks mounted in a more vertical position that end of the car will have a stiffer suspension and thus have less weight transfer to it......this will result in less grip at that end of the car.
Cheers
AndyT  is offline   Reply With Quote
Old 09-02-2005, 05:59 PM   #3789
Team-RTR's Avatar
hey andy u goin to EC today?
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 09-03-2005, 04:27 AM   #3790
Trader Rating: 13 (93%+)
Default frp belt tensioner...
with this rrr wce upgrade, is it possible to adjust the tension of the belt ?
i cant seam to be able to adjust the height of the tensioner.
mrgsr is offline   Reply With Quote
Old 09-03-2005, 06:04 AM   #3791
jeffreylin's Avatar
The height of the tensioner? You adjust the belt tension by rotating the bearing holder slightly. Do you have a manual? if not, you can download one from the kyosho web site.
Old 09-03-2005, 07:17 PM   #3792
AndyT 's Avatar
Oops got ya msg a bit late but yep i raced there yesterday, glad that the weather held up long enough to get thru most of the finals before it rained
Old 09-03-2005, 07:23 PM   #3793
AndyT 's Avatar
The FRP middle i have mounts into where the original went (2 x mounting screws) and then the belt tension is adjusted by moving the bearing/tensioning wheel up and down in its new position on the middle plate.
Cheers
Old 09-03-2005, 07:44 PM   #3794
ghoppa's Avatar
Trader Rating: 54 (98%+)
hey guys,
I'm over here building my new "WC" and I am very upset and SUPRISED that I have some missing parts right out of the sealed box:
  • BRG002: 5x8x2.5mm bearings (2)
  • VZ221: 5mm Posts (2 of them)
  • BRG006: 6x12x4 bearings (2 of them)
  • ORG03BK: P3 O-Rings (none were in the kit)
It really suprised me to see the missing items, and I can get most of them from my LHS, but the 5mm posts are gonna be impossible to get here in town in order for me to finish the kit....
anybody know where I can get V One RRR Parts (on the West Coast perferably) ASAP?????
can anyone help?????
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 09-03-2005, 08:07 PM   #3795
Francis M.'s Avatar
Ghoppa try revelations raceway in montclair ca. for Kyosho parts last time i checked he had kyosho RRR parts or you can contact my friend Yassu at japan RC imports. his web site is not done yet but i can give you his contact info if you like.
Francis M. is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
