Kyosho v-one rrr
Old 08-31-2005, 06:34 PM
  #3766
http://www.mytsn.com/publ/publ.asp?pid=9986
This might help you guys with the roll center questions.
Ted Flack is offline
Old 08-31-2005, 09:07 PM
  #3767
BundyMan's Avatar
I think ziggy is right on this one
BundyMan is offline
Old 09-01-2005, 01:31 AM
  #3768
ziggy12345's Avatar
From the link above
To give a lower roll center, make the suspension arms flatter (more horizontal).
* To give a higher roll center, make the suspension arms more angled. Upper arms would have more of an upward angle where they meet the wheels; lower arms would have more a downward angle where they meet the wheels.
ziggy12345 is offline
Old 09-01-2005, 06:03 AM
  #3769
uaerc's Avatar
Red face
.....sorry guys ! since you are at it...... appreciate if you could show some pictures......
Hope you guys dont mind !
From the looks of it...... my RRR - rear lower arms are quite horizontal and the upper camber link is less horizontol... so what does that make my car ??
More over - Does the holes in the shock tower and the ball link at the bottom also play a part in this ?
sorry if this is silly just wanted to clarfy this doubt.....
uaerc is offline
Old 09-01-2005, 07:13 AM
  #3770
Trader Rating: 13 (93%+)
Default zac tyres and v one rrr track width ?
hey team
ive built my rrr as the box and when i installed the zac tyres i noticed the rear to be 205mm and the front to be about 205mm
with the supplied kit tyres its 199mm front rear
have any of you guys noticed this well ??
apparently the zacs shouldnt have an offset
whats weird is that i screwed in the back pivot ball about a mm on each side and its now 200mm
so i guess maybe the wheels have a 1mm offset ? and the pivot balls werent perfect
mrgsr is offline
Old 09-01-2005, 07:21 AM
  #3771
jeffreylin's Avatar
Originally Posted by mrgsr
hey team
ive built my rrr as the box and when i installed the zac tyres i noticed the rear to be 205mm and the front to be 205mm
weird
The Kawahara tires carries a 1mm offset front and rear.
jeffreylin is offline
Old 09-01-2005, 07:23 AM
  #3772
so is it best to leave it as the book setup and run the zacs ?
or should i screw it in to make it 199mm ?
thanks for your help
mrgsr is offline
Old 09-01-2005, 07:48 AM
  #3773
jeffreylin's Avatar
The legal width is 200mm so if you care to be legal you need to narrow the suspension to use the Kawahara tires.
Old 09-01-2005, 08:08 AM
  #3774
kewdawg's Avatar
I had the terms reversed. My explanation for gaining or losing traction with roll-center is correct. If, you disagree, re-read the article in the link.
kewdawg is offline
Old 09-01-2005, 09:35 AM
  #3775
ziggy12345's Avatar
hey team
Where did you get the ZAC tyres from? I am looking to get a few sets
Cheers
Old 09-01-2005, 06:41 PM
  #3776
AndyT 's Avatar
[QUOTE=uaerc
sorry if this is silly just wanted to clarfy this doubt..... [/QUOTE]
The holes in the shock tower (ie the ones used for the upper shock mount) wont alter the roll centre of the car.
Cheers
AndyT  is offline
Old 09-01-2005, 08:05 PM
  #3777
Cheers
No ... changing your shock position will not effect roll center. Raising or lowering your upper camber link on either end (chassis side or tire side)will cause your roll center to change.
duckman996 is offline
Old 09-02-2005, 12:11 AM
  #3778
Diva's Avatar
Default External centax clutch adjustment tool
How could you adjust the centax clutch spring nuts without dissembling the whole unit? I heard that Team Tamale has made one for Kyosho. Any other idea?
Diva is offline
Old 09-02-2005, 01:49 AM
  #3779
ziggy12345's Avatar
Insert a small allen key in the hole in the clutch bell and this will locate in the slot in the spring retaining nut. Then turn the flywheel with the help of a screwdriver to adjust the spring tension. If you get that far then you will be able to figure out which way it should go to make it tighter or looser
Cheers
Old 09-02-2005, 03:44 AM
  #3780
uaerc's Avatar
Cheers
Andy T
Thanks for the clarification. what part do they play...... does it have anythnigg to do with traxtion.. ? i mean if my shock setting is on the outter hole toward the wheel the shock is more vertical what will it do... ?? hightraction or low.......... and vice versa ?
uaerc is offline
