Kyosho v-one rrr
Old 08-30-2005, 04:46 AM
  #3751
BrainTeased's Avatar
Originally Posted by deviltires
i want to know how can i get the most steering out of my car for some really small tracks right now i have the locker in my front diff with the number 10 steering acer in is there anything else that i need to do to get more steering
here are some ideas i can think of hope it can help
- more rear droop
- decrease front roll center
- decrease rear toe in
- decrease the front track width (the distance between 2 of the front tyres)
- decrease caster (more intial turn in but less mid corner steering)
- increase slightly the front camber angle.
- and running a softer front end.
BrainTeased is offline
Old 08-30-2005, 06:19 AM
  #3752
ziggy12345's Avatar
- more rear droop
And flatten the roll bar
ziggy12345 is offline
Old 08-30-2005, 09:40 AM
  #3753
kewdawg's Avatar
TRY:- Laying down the front shocks.
- Use lighter front shock oil.
- A softer front spring.
- Softer front tires.
- RAISING the roll-center by increasing the height of the front hinge pin mounts.
- Moving the caster clips to the front of the upper arm (when using a front diff or spool).
- Use the #12 servo saver / ackerman(SP?) mount.
Any one, or combination, of these changes should definitely increase your steering.
*Note: Changes made to the rear end will result in "freeing" up the rear, which allows the car to rotate thru the corner better, but will not have enough effect on the front end.
kewdawg is offline
Old 08-30-2005, 09:47 AM
  #3754
Steve Bahnatka's Avatar
i heard these cars are like very expensive....are they?
Steve Bahnatka is offline
Old 08-30-2005, 12:04 PM
  #3755
ziggy12345's Avatar
Originally Posted by kewdawg
- RAISING the roll-center by increasing the height of the front hinge pin mounts..
This will lower the roll centre. If you want to raise the roll centre you have to lower the hinge pins and this will give you less steering response
Cheers
Old 08-30-2005, 12:11 PM
  #3756
freefallmarine's Avatar
It really depend's how hard you look. Iv'e found them from $370 to $420usd. If your intrested, ill look around for you. It's aways good to have another RRR pilot on board..
freefallmarine is offline
Old 08-30-2005, 12:29 PM
  #3757
kewdawg's Avatar
Rich kids like yourself, shouldn't have any diffficulties obtaining one.
kewdawg is offline
Old 08-30-2005, 12:38 PM
  #3758
o, ok kewdawg i see how you doo i guess ill have to get the poormans car...the g4
Old 08-30-2005, 12:56 PM
  #3759
kewdawg's Avatar
Cheers
Just the opposite. The higher and or the more level the camber link, the more traction you'll have.
kewdawg is offline
Old 08-30-2005, 01:00 PM
  #3760
kewdawg's Avatar
You'll be just as fast, don't worry.
kewdawg is offline
Old 08-30-2005, 02:09 PM
  #3761
ziggy12345's Avatar
What I say and what you say are the same thing. The more level the camber link the higher the insert and so the lower the roll centre and more traction but less stability over bumps.
Old 08-30-2005, 02:13 PM
  #3762
Regional Moderator
Darkseid's Avatar
Hey, I'm looking to get a hold of some V-One series front universals. Towerhobbies has all that stuff as discontinued....
...so where are you guys buying parts from???
Darkseid is offline
Old 08-30-2005, 06:14 PM
  #3763
kewdawg's Avatar
I said, "and or" for reason. Depending on the vehicle - Take our RRR for example: the natural(designed) position of the rear camber link has an angle (angled upward). To increase the roll center, you would need to make the link more level (horizontal) by lowering lower the link's outer position - because the inner position only moves further inward, toward the center of the car (you can also increase traction by lengthening the link - depending on the suspension design). On a car with vertical inner camber link mounts (say a TC4, for example) you would have the ability to raise the inner link horizontally, which would also raise the roll-center and increase traction. On our Triple R's rear end, the camber link already has an angle to it. If, you make the link higher, by increasing the outer position, you'll increase the angle and lower the roll-center - thus, reducing traction. The same applies to the front end, which has a natural angle to the upper arm. If, you lower the hinge pin / mount, you will increase the angle, lower the roll-center and reduce traction. The angled link does not allow the car's weight to go to the tire, at that corner of the car, when cornering. The more horizontal OR higher AND horizontal link will allow the car's weight to shift to the wheel in a more linear fashion.
To put it simple, the direction you move the link depends on the links' natural position.
kewdawg is offline
Old 08-30-2005, 10:48 PM
  #3764
Racing4Evo's Avatar
I think both of you are thinking of the same thing just stating it in different manners.
Also, I don't think you can call it increasing or decreasing roll center because the "roll center" is an actual point or points on the car, not a quatitative value .
This is my easy way to figure out roll center. The farther apart the upper and lower arms are from each other, the lower the roll center and the more traction you get at that end of the car.
Racing4Evo is offline
Old 08-31-2005, 04:43 PM
  #3765
ziggy12345's Avatar
Sorry cant let this go!
Your arse about face. Lowering the hinge pin at the front as you mention will RAISE the roll centre
If you make the link at the rear horizontal you will LOWER the roll centre
I will PM you the geometry that will prove this
Cheers
