Old 08-26-2005, 09:44 PM   #3721
Default front diff.
i need help installing and putting together a front diff.
i have all the necessary parts just a few questions
do i put it together the sameway i did the rear diff?if so that means they are the same size right?
does the same belt that goes around the oneway go around the larger diff now?
whats the easiest way to take out the front oneway and put the front diff in?(like what screws need to come out )
oh i do have the wce if that makes any difference.
bosfan is offline   Reply With Quote
Old 08-26-2005, 10:21 PM   #3722
ghoppa's Avatar
Trader Rating: 54 (98%+)
anybody know who makes the front spool that Josh used during one of the qual's at the GLC????
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 08-26-2005, 10:35 PM   #3723
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The front diff is a lot smaller than the rear diff. If you are unsure about it, there are instructions near the back of the manual for the front diff along with part numbers.
The most important thing to remember when assembling the front diff is to not use the pulley flange with the pulley.
The same belt is used.
Yes, the front diff should be easy to install. If you are aware of how to change the front roll center, that's half the process.
-What you need to do is take the shock tower off and the 4 screws that fasten the front bulkhead caps.
-Slide off the caps and pull the one way up first, then twist is to free it from the front belt. You should take out the bearings in the process to make your job easier.
-Fit the bearings on the front diff the way they came off the one way and slip the front belt over the pulley.
-It will be hard at first to push the diff down into position because of the akward angle which stretches the belt slightly(not enough to cause harm), but once down you should be able to reinstall the dog bones and front bulkhead caps easily.
-Take care to make sure both left and right bearing cams are in the same position when you reinstall the bulkhead caps.
-Reverse the disassembly of the shock tower.
Racing4Evo is offline   Reply With Quote
Old 08-26-2005, 10:41 PM   #3724
Racing4Evo's Avatar
He got that from a guy in Texas during the Sedan Nationals. It's actually very neat. My friend got one as well. It's still a one-way but instead of the two outdrives spinning independent of each other on a normal one-way, the two outdrives are connected so that when on power both wheels rotate at the same speed regardless if the car is on 3 wheels. It's really stable on bumpy tracks. There is a pin you insert in the center like the serpent oneway that locks the entire thing.
I'll see if I can get the guy's contact information.
Old 08-26-2005, 10:45 PM   #3725
Racing4Evo's Avatar
thanks dude "that's it"a rear shock tower???????? sweet, would you happen to know where I can get Ron Atomic's set up from the RD Logics race
you gonna make it to vegas for the race??????
If I remember correctly, Ron said his car was on the stock setup except for the rear shocks being all the way down and the long position for the camber link.
The stock setup works really good for Vegas. The best tires to use were 40F and 42R at 62mm in the rear and 61mm in the front.
Old 08-26-2005, 11:08 PM   #3726
ghoppa's Avatar
yeah Peter,
if you can get the info on they guy in Texas, that "would be great", I wonder how it would be for our track here in Vegas....never know unless you try it......
thanks,
Old 08-26-2005, 11:20 PM   #3727
freefallmarine's Avatar
Anybody run 10,000wt rear diff's with 30,000wt front diff's for parking lot racing? just wondering if i should keep the 30,000 rear and go 50,000 in front. or change it for better steering on tight tracks. Thanks .
freefallmarine is offline   Reply With Quote
Old 08-26-2005, 11:41 PM   #3728
Racing4Evo's Avatar
yeah Peter,
thanks,
I think it would be great for Vegas. I've never driven the track with the pork chop but for the layout at RD, it was pretty much point and shoot. I wish I didn't have such horrible engine problems.
Old 08-27-2005, 01:53 AM   #3729
ziggy12345's Avatar
A normal one way will spin the wheels at the same speed on power as well. If the axles are locked it will add turn braking on corner entry same as a locked diff but will have the disadvantage of no brakes!
I cant see the point.
The guys here take a normal one way tube and lock the drives in like a locked diff but its half the weight.
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-27-2005, 02:02 AM   #3730
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
You should run your belts as loose as possible on large flowing tracks where you are smoother on and off the throttle. The belts should be tight on small technical tracks where you are using a lot of short bursts of throttle or else you could snap the belt. There's no effect on handling that I have noticed, just on acceleration. Whatever the condition I like to run the belts on the loose side for top speed and fuel milage.
thanks... will try that set-up then our track is teachnical and medium sized and a bumpy...
doki_doki is offline   Reply With Quote
Old 08-27-2005, 02:37 AM   #3731
luketob's Avatar
Can someone maybe explain what does it do to the car if you change front upper arm and lower rear arm position? what doest it do if you move it all the way up/down. the stock setup works great for me, just want to try something out, maybe someone can give me heads up. thanks
luketob is offline   Reply With Quote
Old 08-27-2005, 02:45 AM   #3732
luketob's Avatar
one more thing....i don't know if it's has been discussed or not, but with the lower arm pos. on medium high, a 12.5mm shock length is not long enough for the droop screw to touch the chassis. Is it normal or not? Should it use medium ball end instead of short ones?
Old 08-27-2005, 07:16 AM   #3733
Dynamite's Avatar
Send a message via MSN to Dynamite
changes your front/rear roll centers.
from memory, the higher the front upper hinge pin the lower the front rollcenter, and higher the rear lower hinge pin the higher the rear rollcenter.
also regarding your shock end cups, i fairly sure i used the medium sized ones front and rear, built them to std specs and havent had a problem... hope this helps.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 08-27-2005, 07:36 AM   #3734
Trader Rating: 13 (93%+)
Default drove the rrr today for the first time ... questions....
hey team
upgrading from the fw-05rr to the v one rrr is a dream come true
the car was sooo nice to drive i loved it.
however the only way i could get it to stop sliding out on power was to have -4 toe in at the rear, i know this sounds excessive and yeh its robbing my top end and tire wear. im using the stock setup with 37 shore tyres on a medium grip parking lot track.
can some one please recommend some other things i can try with my toe in at a reasonable amount like -2 ??
maybe i should swap the springs around and go a softer rear ?
thanks
JOhn
mrgsr is offline   Reply With Quote
Old 08-27-2005, 07:47 AM   #3735
Dynamite's Avatar
hey mrgsr.
sounds like you need to try lighter shock oil, springs and rear swaybar. also try using the inner hole for rear camber links. remember try one thing at a time!
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
