Old 08-25-2005, 07:51 PM   #3706
Mie3R's Avatar
Default gear ratio
my shiftpoint is set according to track layout. i think it works fine so far. i plan to use 15/60 20/55. fr tyre 59 rr tyre 61. would it be much diff between 15/61 n 20/56?
doki: run with loose belt setting. smoother n faster at the long straight.
ziggy : refer to Rc world mag on how to DIY anodised stuff.
Mie3R is offline   Reply With Quote
Old 08-25-2005, 08:12 PM   #3707
impalabob64's Avatar
Send a message via AIM to impalabob64
Default gear ratio
15/61 ,20/56 would be better the car will be real aggressive with this gear ratio.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 08-25-2005, 09:18 PM   #3708
Mie3R's Avatar
tq very much 4 ur tips
Old 08-26-2005, 03:40 AM   #3709
Hi all,
Need help on my clutch, When the engine starts, the clutch doesnt engage at idle, however 5 seconds later, still at idle, the clutch engage. I need help.
I followed it at 1.2mm for the spring.
Tiger
tiger266 is offline   Reply With Quote
Old 08-26-2005, 05:13 AM   #3710
Mie3R's Avatar
1 mm would be better. check ur engine idling. maybe to high. also check ur shimming. ur clutch bell must be free..
Old 08-26-2005, 06:39 AM   #3711
abt the shims for the clutch bell. it says to use 5x0.1mm and 5x0.5mm shims. I have no idea which one are those, could u guys point it out? and do i use one for each type?
Old 08-26-2005, 08:03 AM   #3712
NiMo's Avatar
Originally Posted by tiger266
Hi all,
Tiger
your clutch bell is too close to the clutch!!
yous will need to put a few shims between the bearing and the threaded parts of the SG shaft to push the clutch bell away from the clutch.
I now run about a 1mm gap between the clutch bell and the clutch shoe, and almost zero play at the thrust bearing end, clutch is now sweet and easier to tune in.
NiMo is offline   Reply With Quote
Old 08-26-2005, 09:18 AM   #3713
Kinda New to the centax clutch, as to where to put the shims, is it in between the clutch bell and the shoe or clutch bell and the screw at the end of the bell?
Old 08-26-2005, 11:03 AM   #3714
Mie3R's Avatar
tiger266
u must put the shims b4 u put the 1st clutch bell bearing until it turns smoothly(no contact with the clutch shoe). while assembly the thrust bearing also u must make sure its free. good luck
Old 08-26-2005, 02:28 PM   #3715
ghoppa's Avatar
Trader Rating: 54 (98%+)
jeffery,
any recommended/nessesary "hop ups" to add to a "box stock" rrr wc????
getting ready for the paris race and I'm switching from Mugen......
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 08-26-2005, 06:02 PM   #3716
AndyT 's Avatar
Kyosho part # 96643
AndyT  is offline   Reply With Quote
Old 08-26-2005, 07:54 PM   #3717
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by ghoppa
jeffery,
skyline rear 4mm shock tower and that's it!
jeffreylin is offline   Reply With Quote
Old 08-26-2005, 08:01 PM   #3718
ghoppa's Avatar
thanks dude "that's it"a rear shock tower???????? sweet, would you happen to know where I can get Ron Atomic's set up from the RD Logics race
you gonna make it to vegas for the race??????
Old 08-26-2005, 08:05 PM   #3719
bighurt98's Avatar
Default RRR with a floating rear body??
I am asking this question again to see if anyone has tried putting the V One R Evolution front bumper and floating rear mount onto the RRR. The Open nationals are in November and was considering runniing the RRR in 1/10 Outlaw with the Lola Body. Is it better to say with the standard RRR setup and attach the Lola body?
Any help would be great!
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 08-26-2005, 08:10 PM   #3720
jeffreylin's Avatar
Ron is on the Skyline and the OS thread so you might want to post your request there. I am not planning on going to Vegas but Jeffery Lin from OFNA might.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
