Old 08-19-2005, 12:04 PM   #3661
luketob's Avatar
look back a few pages, it has all been discussed with many available answers
oh ok...thanks nimo
luketob is offline   Reply With Quote
Old 08-19-2005, 09:12 PM   #3662
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Default Help for leftr front bulkhead cap.
I was trying to assemble my new V one RRR WC editions and found out it was missing the part#21 lrft frnt bulkhead cap. Does anyone know where I ca get one quick? Thanks!
fpart is offline   Reply With Quote
Old 08-19-2005, 10:06 PM   #3663
jeffreylin's Avatar
R/C Tech Charter Subscriber
Call Kyosho America they can probably help you with it.
www.kyoshoamerica.com
jeffreylin is offline   Reply With Quote
Old 08-20-2005, 12:47 AM   #3664
try rc-toro.com. I bought some parts from them before. fast shipment. good price
silverM3 is offline   Reply With Quote
Old 08-20-2005, 04:56 AM   #3665
BrainTeased's Avatar
hi guys
did the RRR come with 15/20 pinions? and 56/61 spurs
if so did you guys strip the 1st gear spur pretty quickly?
also which one is the over drive pulley? 23T yea?
also may i ask the internal ratio of the car
with the 23T side pully installed and the 24T side pulley installed.
thanks in advance guys
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 08-20-2005, 05:12 AM   #3666
NiMo's Avatar
Originally Posted by BrainTeased
hi guys
16/21
I have stripped 12 1st gears in 4 meetings, they sit too low to the ground and pick up all the debris.
23T is overdrive, 24T for equal tyres and Rubbers
not got ratio list to hand but the 21T is plenty good enough for a 155ft straight.
NiMo is offline   Reply With Quote
Old 08-20-2005, 05:47 AM   #3667
ziggy12345's Avatar
I have stripped only one first gear and one second gear.
Check the length of the rear engine mounting screws. The rear ones are the same holes for the engine to mount screws and the chassis to mount screws. There is only .2mm gap between the 2 when tightened so if you have an oversize screw they will touch and not clamp the chassis to the mount and the engine will move around stripping the gears.
Thnak EVO2 for that bit of Lessons Learned after Mendip national
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-20-2005, 06:03 AM   #3668
thanks Nimo
im using the right side pulley than (24t) cause i run rubbers
i think i found out why my spur gear stripped so quickly!
Originally Posted by mrgsr
hi again
i got rid of the slack by loosing the set screw that holds the 2 speed clutch shoes onthe shaft and pulling the shaft throught from the other side where the pull ey is then tightening back down the set screw.
however now there is about 2mm of movement
not sure if this right ?
thanks for any help
john
i did exactly what he did so maybe the spur gears could not spin as freely as the pinion gears.
and later checked and noticed my grub screw on that 2 speed hub housing was loose so might have made the 2 speed shaft swing side to side causing me to strip gears.
Thanks ziggy for your advice as well but i run the Vones 3 so im using the stock engine which doesnt use engine mounts. but i know what you mean
cheers guys
Old 08-20-2005, 08:19 PM   #3669
FW-05RR's Avatar
is anybody running the new Novarossi N12LL3 on their V one RRR WC? Is this a good car/engine combo..?
FW-05RR is offline   Reply With Quote
Old 08-20-2005, 09:58 PM   #3670
Trader Rating: 19 (100%+)
Does anyone know of a good site for setups for the V one RRR WC?
Lots of setups at http://www.kyosho.co.jp/web/download...g/index-j.html, their all in Japanese, but if you have an English setting sheet to reference, you'll be fine.
sjr456 is offline   Reply With Quote
Old 08-20-2005, 10:28 PM   #3671
impalabob64's Avatar
Send a message via AIM to impalabob64
Default gearing
hey the gearing i use on shorttracks 15/59,20/55, 58mm frt,60mm rear ,my engine evo3 by sirio.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 08-21-2005, 07:43 AM   #3672
uaerc's Avatar
hi
Is it possible to let me know what kinda tire truer you are using to trim your tires......
uaerc is offline   Reply With Quote
Old 08-21-2005, 11:24 AM   #3673
NiMo's Avatar
Days racing ruined again.
Another stripped rear drive belt, and this time I had it on the tight settings. also my last order for more rear belts is on hold as none are available.
Guess it was my last race with the RRR as I have no hope in the championship with all these retirements, I'm going back to the trusty old FW05, it may not be as quick on the infield, but at least it gets to the finish line, and is also much cheaper to run.
Old 08-21-2005, 11:48 AM   #3674
ziggy12345's Avatar
Are you using the metal rear pulley? I stripped a rear belt today but it was the first outing with the metal pulley
Cheers
Sponsored by:
Norfolk and Chance
Old 08-21-2005, 11:57 AM   #3675
NiMo's Avatar
Cheers
Nope, kit pulleys.
and it went so suddenly that the car understeered in to the barriers smashing a front hub and suspension arm (i have yet to check the other bits).
Not sure if I can make the Cotswold meeting now.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
