Kyosho v-one rrr
Old 08-17-2005, 09:21 PM
  #3646
C_O_jones's Avatar
jeffreylin, thanks for the info to the link.
drfritz, Thank you too!
Found what I was looking for.
Do you run foams or rubber tires in Portland ?
I ran elect at your clubs tennis court race, but it started raining before I got a chance to check. Did have a great time there.
Fred
C_O_jones is offline
Old 08-18-2005, 04:54 AM
  #3647
Grinder's Avatar
Anyone know of a floating rear body mount that will work on the RRR?
Grinder is offline
Old 08-18-2005, 06:25 AM
  #3648
Trader Rating: 14 (94%+)
Originally Posted by NiMo
You may need to shim it between the shaft bearings and the bulk head.
You want as little play as possible but making sure that none of the parts are binding at any point.
which side should i shim it ?
as in between the clutch shoes and bulkhead or the other side between the bulkhead and plastic collar where the pinion is ??
thanks
is this normal ?
ive built as the book except for the aluminium East brake holder
mrgsr is offline
Old 08-18-2005, 09:03 AM
  #3649
any recommedation on not to loose control when entering a corner? i'm a noob and everytime I enter a corner my car will just spin! is it the tyre setups or my personal problem? I'm using 37 and 40 rear.
nero1943 is offline
Old 08-18-2005, 09:20 AM
  #3650
NiMo's Avatar
One-way, Spool or Diff?
I use 40 front 42 rear with a diff
NiMo is offline
Old 08-18-2005, 09:37 AM
  #3651
i have a wce and everything is pretty much stock. Same goes with shock oil 30k at the rear diff
nero1943 is offline
Old 08-18-2005, 05:35 PM
  #3652
AndyT 's Avatar
Are you using the brakes with the one way diff whilst cornering?....if youre running a front one way diff and use the brakes whilst cornering, then the car will have a tendency to want to spin.
AndyT  is offline
Old 08-18-2005, 06:03 PM
  #3653
drfritz's Avatar
Fred
foams all the way,I run from 35 to 40 shore, it all depends on what they put down for traction that day, we got a race this Saturday at Jantzen Beach Mall, check out the clubs web page for more [email protected] http://www.rc-cars.com/
drfritz is offline
Old 08-18-2005, 06:07 PM
  #3654
drfritz's Avatar
Well, I did hear there is a new car in the works, maybe thats what they have changed on the new model, if not, time to do some old fashion fab work to make your own..
drfritz is offline
Old 08-18-2005, 06:45 PM
  #3655
Moderator
Uneke's Avatar
Does anyone know what engine pipe combo that Josh Cyrul ran at the Great Lakes Challenge or just in general?
Uneke is offline
Old 08-18-2005, 07:42 PM
  #3656
jeffreylin's Avatar
Sirio engine & pipe. He is sponsored by Sirio.
jeffreylin is offline
Old 08-18-2005, 08:09 PM
  #3657
FW-05RR's Avatar
I used to have a Sirio Engine that came with a kit I bought and everyone told me they were garbage now ever since the worlds in Brazil took 8 out of 10 spots now they are considered really good motors Novarossi is still the best in my book
FW-05RR is offline
Old 08-19-2005, 02:58 AM
  #3658
luketob's Avatar
hi guys,
i just finished building the car. I have no problem so far with the parts but how do you route the wire in the car?. I'm trying to make the wires sit in a safe place, not too close to the gears. Maybe someone can help me how do you wired the car, it's really helpful if you can share some pics too. Thanks
Attached Thumbnails Kyosho v-one rrr-dsc00248.jpg   Kyosho v-one rrr-dsc00251.jpg
luketob is offline
Old 08-19-2005, 06:55 AM
  #3659
NiMo's Avatar
Originally Posted by front1wayFreak
hi guys,
look back a few pages, it has all been discussed with many available answers.
NiMo is offline
Old 08-19-2005, 10:32 AM
  #3660
fpart's Avatar
Trader Rating: 40 (100%+)
Does anyone know of a good site for setups for the V one RRR WC?
fpart is offline
