Old 08-13-2005, 03:14 AM   #3616
freefallmarine's Avatar
Originally Posted by NiMo
A solid will give a quicker turn in and more on power steering but it will make the rear a little loose.
A diff will keep more grip in the rear but you will not have as much front end turn.
I use the TCD in the rear diff (reduces power on spin outs) and 50k in the front diff but my track is mostly sweeping corners.
Will the stock springs be ok or should i get black's for the rear? Once again thank's Nimo.
freefallmarine is offline   Reply With Quote
Old 08-13-2005, 01:31 PM   #3617
Default new guy
i just bought a:
rrr wc serio, futaba
pro spec nova, futaba
and reading what you guys are talking about, " i'm gunna have some questions! " istill have to build them, i need to get the recievers, liquids, and maybe a couple of upgrades if you guys know anything i should do right out of the box? thanks
anthony750 is offline   Reply With Quote
Old 08-13-2005, 01:57 PM   #3618
NiMo's Avatar
Not really tried a Rubber set up on the RRR, but on the FW05 I went much softer on the springs, on that I actually use the Orange and Yellow springs from the Kyosho Pure10 Mk2.
NiMo is offline   Reply With Quote
Old 08-13-2005, 10:40 PM   #3619
bighurt98's Avatar
Default 1/10 Outlaw (200mm) changes needed!!
OK! I will be attending the 2005 Fuel Open Nationals in Kissimmee, FL in November. I want to change a few things to run the Lola or GTP bodies.
Does the Evo RR front bumper and plate work on the RRR?
What changes are needed to do so if you have any!
Also, does the rear floating body mount from the Evo RR work on the RRR?
Any modifications needed to get it to work?
Has any hop-up maker decided to make a conversion kit to change from WCRRR to 1/10 Open RRR?
Thanks!
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 08-14-2005, 11:47 AM   #3620
i am currently running rubber in the uk national series, have found a good base set up to start from, give it a try
Front end
5mm ride height
black spring
3x1mm pistons (made out of standard 2x1)
50wt oil
shocker in most upright postion
roll center inserts to top
run as little castor as you can to help on low speed corners
ft diff using mugen super grease (or 100,000 wt at least)
1 deg camber
1 deg toe out
Back end
5.5mm ride height
silver spring (black if you find the rear of car is planted)
4x1mm piston
50wt oil
shocker 2nd hole from top
roll center insert at bottom
then the ball joint on the outside of the camber link turn it over,
the main problem running the rrr on rubber tyres, there is far too much camber change on the rear end, it either burns the inside of the tyre out or simiply the back end breaks away far too easy. next meeting will be trying a longer camber link to see if it helps
rr diff 5,000wt
3 deg toe in per side
1.5 deg camber
give it a try see what you think
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 08-14-2005, 12:17 PM   #3621
NiMo's Avatar
After stipping another rear belt yesterday I thought I'd try something different so I set the rear belt tension to tightest and the side belt to 384 (with 24T pulley), Strangely enough the rear end twitching vanished and the car would turn in better.
My best at the track is a 21:307, today I done 21:312 which sounds bad (2 grassy moments), but my nearest rival was on 20:306 and he said the track was slow, so maybe it is better.
Old 08-14-2005, 02:29 PM   #3622
ziggy12345's Avatar
Swap the rear belt tentioner left for right. You can tighten the belt more so it wont slip. SP belts stretch more than the kit ones
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-14-2005, 02:40 PM   #3623
NiMo's Avatar
Cheers
That could have been my problem, I was trying to keep them as loose a possible to reduce drag, but the car feels better now and the 384 belt is not tight.
Old 08-14-2005, 08:18 PM   #3624
AndyT 's Avatar
-Change the stock brake disc to something like the Kawahara or 3-racing disc.
-Change the stock rear shock tower to something like the Skyline 4mm.
- Fit the Skyline exhaust mount.
Cheers
AndyT  is offline   Reply With Quote
Old 08-15-2005, 04:01 AM   #3625
Default 3D clutch shoe
I'm having trouble getting a clutch shoe replacement for the RRR here locally in Aust. Are there other brands and/or any of the previous model shoes that fit?
Rumage is offline   Reply With Quote
Old 08-15-2005, 05:52 AM   #3626
AndyT 's Avatar
Have you tried Rc Addict in Melbourne?, theyre usually good for RRR parts-
www.rcaddict.com.au
Old 08-15-2005, 03:26 PM   #3627
Front end
5mm ride height
black spring
50wt oil
1 deg camber
1 deg toe out
Back end
5.5mm ride height
4x1mm piston
50wt oil
rr diff 5,000wt
1.5 deg camber
Thank's jas1 Im going to test tommorow.
Old 08-16-2005, 11:40 AM   #3628
Would the WC KIT setup with front dif (not one way) be good for a small technical track?
That is front diff with wc kit stock setup.
Tiger
tiger266 is offline   Reply With Quote
Old 08-16-2005, 11:48 AM   #3629
would be ok, but could benefit from using lighter oils in the diff.
Im 10,000 at the rear and 30,000 at the front.
rcrossco_1 is offline   Reply With Quote
Old 08-16-2005, 05:44 PM   #3630
Trader Rating: 13 (93%+)
Default got my rrr yesterday ..
bye bye fw 05rr
gonna miss that car but time to try a belt car
so far so good however i hate when the flange balls are tight inside the eyelets. what do you guys do to help free it up ?
thanks
John
mrgsr is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
