Old 08-08-2005, 07:53 PM   #3571
FW-05RR's Avatar
Originally Posted by FW-05RR
guys whats the difference between
V-One RRR WC Team Edition
No.31258
and
No.31258B
can anyone help me with this question?
FW-05RR is offline   Reply With Quote
Old 08-08-2005, 07:53 PM   #3572
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by silverM3
Kyosho shimo one piece mount is expenisve. It is like $30+. Very hard to find also. I tried rc-mushroom. But, it is out of stock now. Where did you get it? thx.
Try Pro Shop Futaba ([email protected]) or Champ RC (champ_internati[email protected]). Email them and give them the part number(s) and they will quote you.
jeffreylin is offline   Reply With Quote
Old 08-08-2005, 07:57 PM   #3573
jeffreylin's Avatar
I think one is rubber tire edition and the other foam edition. So if you got the foam edition don't worry about the other one.
Old 08-08-2005, 08:02 PM   #3574
FW-05RR's Avatar
ok thanks Jeff
Old 08-08-2005, 08:58 PM   #3575
Help!! Off Power push. I run on a medium bite medium size track with a lot of 180's. I run RRR wc box stock setup, The only thing I've changed was Gold springs in the rear and silvers up front. Shocks are stood up on both towers.
I've tried the Diff and onway with this setup but I still get that push. Anybody out their with a good front Diff set up? With all those 180's thought a diff might be better. Have not tried a spool yet.
PhatPat is offline   Reply With Quote
Old 08-08-2005, 09:10 PM   #3576
AndyT 's Avatar
I got mine thru rc-mushroom, but i think from memory that they may also have them at- www.rcaddict.com.au
AndyT  is offline   Reply With Quote
Old 08-08-2005, 09:11 PM   #3577
jeffreylin's Avatar
More droop in the rear, less castor, lighter rear diff oil, lay down your front shocks, and hitting brakes would all help, but don't do all of them at the same time!
Old 08-08-2005, 09:18 PM   #3578
Thanks, I will do all. as far as diff. 10000 rear & 50000 front sound OK
Old 08-08-2005, 09:19 PM   #3579
AndyT 's Avatar
You need to get more weight transfer to the front of the car to give your more steering.....try the front shocks back in the stock mount position...having them stood up at the front will reduce weight transfer/steering.
Also check diff oil that its not too heavy in the front diff.....you`ll lose more off-power steering if/when you change to a spool unless you resetup the car for it.
Also check droop....take it back to the stock settings and work on tuning from here.
Cheers
Old 08-08-2005, 10:09 PM   #3580
Cheers
That makes so much sense!! How dumb can I Be!! I get to the track and go brain dead.
Old 08-09-2005, 01:38 AM   #3581
Registered User
xrcbuggy's Avatar
Who has good parts selection for this car in US? I read parts are hard to find in US.
xrcbuggy is offline   Reply With Quote
Old 08-09-2005, 04:20 AM   #3582
There isn't a way to convert the wt numbers to cps numbers as they differ from manufacturer to manufacturer. But usually 30wt is close to 400cps and 40wt is close to 500cps etc. The following web page provides more information and explanations:
http://www.twf8.ws/new/tech/tip/shock.html
Thanks Jeffrey, I will check it out.
CHUCKMANDO is offline   Reply With Quote
Old 08-09-2005, 07:33 AM   #3583
NiMo's Avatar
I would think that with a lot of 180's you should use a spool, it gives more turn in and more on power steering than a diff but it will make the rear end step out when off power so watch out in any sweeping bends.
My track has a lot of sweepers which is faster with a one-way but the 2 main passing points are relying on heavy out braking moves so you need the brakes on the front end which is why I use a diff.
NiMo is offline   Reply With Quote
Old 08-09-2005, 09:04 AM   #3584
kewdawg's Avatar
Use 30,000 wt. diff oil, up front, to increase diff action. This will increase your steering, in addition to, laying down the shocks w/ the softer spring. You may also want to use lighter shock oil. Move the spacers to the front of arms. The increase increase in castor will give you more off-power steering.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 08-09-2005, 09:48 AM   #3585
Thanks for the help.
I'm the pioneer RRR driver in a serpent and NTC3 world. The car was better than most with my jacked up setup. With the help on this forum this car is gonna be killer.
Is their a big difference in steering with the number 10 and 11 servo saver?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
