Old 07-20-2005, 04:12 AM   #3376
ziggy12345's Avatar
Originally Posted by jas1
I,m after a bit of feedback from some experienced foam drivers on setting up my rrr, i generally run my car of rubber tyres, and have only dabbled with foams.
i nead a quick crash coarse, i am racing in the euros at the halifax trark in the uk in 4 weeks. it is my local track luckily but this sunday is gonna be my last chance to practice.
the track is large and fast flowing, but only mid-low grip most of the time. some bumpy sections also that can catch you out under braking also
any help would be greatly appreciated. cheers
Jas1 Dont see you on this site very often. Here's my advice for what ist worth (you've seen my driving!!)
Change then roll centre at the front so the inserts have the pivot holes at the top. This gives you a sharp turn in. Caster clips can be all forward
You will find you need to trim the steering down so it doesnt spin out but you can use less lock so wont loose speed in the corners.
Use the solid front axle. If you can get a spare one way tube mod it to turn it into a solid as it's half the weight of the diff conversion.
Tyres are no bigger than 62 rear 60 front. Even 60/58 is good for a heat. If you can get the new Jacos I would try them.
I changed the battery pack for AAA and moved it forward. It lasts a final easy
Best of luck for the euros
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-20-2005, 01:19 PM   #3377
cheers ziggy i'm gonna need it.
been thinking of using a AAA battery pack, but running rubber tyres have the battery at the back, really strugguling to keep the back end planted running rubbers.
tried the 1 deegree castor blocks last sunday, they sharpened the front end up no end, just ordered some 2 deegree to try.
will give the solid a try, but the one way did feel pretty good, plus when grip comes up i would say you'll probably only need the brakes once a lap, but i will try it.
have found the car only seems too work on small tyres, only problem with that the engine is screaming its nads off at the end of the straight
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 07-20-2005, 08:33 PM   #3378
Default servos?
i just got a rrr, i bought a serio .12 evo 3, an rd logics pipe, and i heard that some servos don't work well in some cars. i use a xs 3, and a rs 310 rx, can someone let me know what servos do well in this car?
anthony750 is offline   Reply With Quote
Old 07-21-2005, 12:53 AM   #3379
i have ko 2364 on my v1rrr wce.
silverM3 is offline   Reply With Quote
Old 07-21-2005, 02:01 AM   #3380
ziggy12345's Avatar
Are you using the 23t gear? I found that the smaller tyres work really well. It makes about 1/2 sec a lap around Ashby.
Sponsored by:
Norfolk and Chance
Old 07-21-2005, 04:17 AM   #3381
Hi guys. New to rc here.
Right now when I hand-spin my first gear, my second gear spins too.
What i would like to know is whether the first gear is supposed to spin with the second gear or should the second gear remain still?
and also when I hand-spin my 2nd gear, my 1stgear spins too.
Should the 1st gear remain still when the second year is spinned?
Tiger
tiger266 is offline   Reply With Quote
Old 07-21-2005, 06:19 AM   #3382
NiMo's Avatar
Tiger
You need to make this clearer.
Is this with the motor/clutchbell in the car?
NiMo is offline   Reply With Quote
Old 07-21-2005, 08:05 AM   #3383
dodo's Avatar
Send a message via Yahoo to dodo
Tiger
if you're talking about the spur gears, try loosen the grub screw that holds the clutch and tighten it again, the manual asks you to tighten the grub screw 1st. while it's better to tighten it last (after you install the 1st gear) to make sure that there is enough 'play' between the 1st gear holder and clutch, thus they don't bind.
dodo is offline   Reply With Quote
Old 07-21-2005, 08:38 AM   #3384
its the gears that are connected to the chassis not the engine.
Old 07-21-2005, 08:52 AM   #3385
jeffreylin's Avatar
R/C Tech Charter Subscriber
Tiger
Depends on the direction you are spinning the gears. I don't have my car with me to verify but it sounds fine.
jeffreylin is offline   Reply With Quote
Old 07-21-2005, 06:14 PM   #3386
AndyT 's Avatar
I`m using the Futaba S9451`s on both throttle & steering and they are outstanding.
If you plan on fitting these to a RRR, note that the 9451`s require different spacing to other servos (top of page 23).
AndyT  is offline   Reply With Quote
Old 07-21-2005, 06:20 PM   #3387
AndyT 's Avatar
Tiger
If the engine is out, then both spur gears (the plastic gears) should spin freely of each other......with the engine and pinion gears in 1st and 2nd spur gears will rotate together.
Old 07-22-2005, 04:55 AM   #3388
now that both are spinning together, how do i make them spin freely of each other? loosen the grub screw in the clutch?
Old 07-22-2005, 08:39 AM   #3389
kewdawg's Avatar
I'm currently using a hitec 5625 MG Digital for steering. Strong and fast. Using a hitec 625 MG for throttle / brake. Strong stuff. They work great.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-22-2005, 05:39 PM   #3390
AndyT 's Avatar
If they wont spin freely of each other with the engine out.....check the 2nd gear (the one with the housing attached), pop it onto the shaft and see if it can rotate freely or whether its dragging on the 2 speed shoes.
If its dragging on the 2 speed shoes....check that youve wound in the grubscrews (the ones over the rollers) enough so theyre not protruding and dragging on the 2 speed case.
If theyre wound in and still the 2 speed case is dragging on the shoes.....then you may have wound the grubscrews in too far...these move the 2 speed shoes outwards (so it may "locked" in 2nd gear)...loosen them off a bit and then check to see if its rotating freely.....keep making very small adjustments to this till it rotates freely.
Cheers
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
