Old 07-11-2005, 12:03 PM   #3316
Originally Posted by jeffreylin
The diff shouldn't leak if you built it per instruction. One thing that was not clear in the instruction is how much diff oil you should put in it. I have them just slightly covering the bevel shaft or perhaps 60-70 percent full. If you fill it to the top there will be too much oil inside and it will leak and your diff won't work right.
in my instruction manual for the world editon car, it says to put glue on top of the orange gasket that you put in the inside slot of the plastic gear box. i did not put it there, but it might help.
Joe Chaplow is offline   Reply With Quote
Old 07-11-2005, 12:07 PM   #3317
NiMo's Avatar
From experience you do not fill the diffs with oil.
Only fill until the Bevel Shafts are covered otherwise you'll get a pressure build up that will break the seals and rubber rings.
I dont glue any part of my diffs and have not had a problem with leaks
NiMo is offline   Reply With Quote
Old 07-11-2005, 12:10 PM   #3318
jeff, you goint to be at the nationals in Texas?
Old 07-11-2005, 12:11 PM   #3319
jeffreylin's Avatar
R/C Tech Charter Subscriber
joe and svine, this is a list of hop ups I have on my RRR:
evolva pivot balls (might be included in WC kit)
low friction belts (in WC kit)
carbon front shock tower (in WC kit)
universals front and rear (in WC kit)
aluminum wheel hexes (in WC kit)
new upper deck (in WC kit)
rfp battery plate (in WC kit)
side belt stablizer plate (in WC kit)
aluminum brake holder (in WC kit)
lightweight first gear holder (in WC kit)
shimo engine mount (in WC kit)
kyosho ti steering turnbuckles
kyosho aluminum brake lever
kyosho v1r hollow front shaft
kyosho ti 2 speed shaft
kyosho SP brake pads
kawahara vented brake rotor
skyline 4mm rear shock tower
everything else stock.
jeffreylin is offline   Reply With Quote
Old 07-11-2005, 12:17 PM   #3320
jeffreylin's Avatar
nah, been traveling too much lately as it is plus its HOT!!! Jeffery Lin from OFNA will be there though (but obviously not me). He is very fast and a friend of mine. If you need help with your RRR Ron Calangi will be there. He is a Kyosho driver, super fast and one of the nicest person you'll ever meet.
Old 07-11-2005, 12:30 PM   #3321
cool, thanks for the referrals.
Old 07-11-2005, 12:33 PM   #3322
also, just realized, i put an upgraded kyosho disc brake in the car. i did not weight it, but it seems to be heavier, this might be another reason why i am a tad heavy.
Old 07-11-2005, 12:34 PM   #3323
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Everything else stock??
You don't have anything left, everything is hopups (j/k)
BTW: your car looked really good yesterday, that was a fun race
Walter Diaz
wad is offline   Reply With Quote
Old 07-11-2005, 12:39 PM   #3324
wad
wad's Avatar
I agree on that one
Walter Diaz
Old 07-11-2005, 12:41 PM   #3325
it is supposed to be in the 70's this week... come out to texas!!!
Old 07-11-2005, 12:50 PM   #3326
jeffreylin's Avatar
Thanks Walter. and remember, that was with battery plate dragging under the chassis (forgot the two rear screws) and a broken rear shock tower (original Kyosho one--replaced with the Skyline one since) for the entire race.
For those who weren't there, my car was in such a sorry state of disrepair because a turn marshall stepped in front of my car and then fell and stepped ON my car before the previous race I was supposed to be in. He broked my fuel tank and the shock tower. I was allowed to race the next race but only had 15 minutes to repair my car. 15 minutes was only enough to put in a new tank so I couldn't replace the cracked shock tower. As I was in such a hurry I forgot the two rear screws for the battery plate that was removed while fitting the fuel tank. Still, the car was competitive!
Old 07-11-2005, 01:14 PM   #3327
wad
wad's Avatar
I see you had a good day
For me was fun also to break my car during warm up, then fix it within 1 minute and go race with 0.5 toe out on the front right tire and 4.0 toe out on the front left tire
Is fun to be racing with a car that has really big push when you turn to the right, and a lot of steering when you turn to the left
Oh I forgot, my car never went straight on the straightaway
Walter Diaz
Old 07-11-2005, 01:16 PM   #3328
jeffreylin's Avatar
We should have a broken car race.
Old 07-11-2005, 01:19 PM   #3329
wad
wad's Avatar
yeah, that sounds good
Walter Diaz
Old 07-11-2005, 01:56 PM   #3330
YBSLOW's Avatar
Default Cool
Just make everyone start the race using a spectrum, then you will have a broken car race.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
