Old 07-11-2005, 07:10 AM   #3301
jrabbito's Avatar
Not true...I have a few that I feel are very important. Not NEEDED though...
WC Edition kit + these upgrades
Kawahara rear adjustable sway bar (Blade style)
East Ventilated Brake disc (The stock one isnt very good)
Skyline Rear shock tower (4mm thick)
Titanium middle shaft - East
Kawahara steel pinions
Its all for durability/performance and none are really needed...
John
jrabbito is offline   Reply With Quote
Old 07-11-2005, 07:30 AM   #3302
NiMo's Avatar
He asked what was really needed, and with the WC none are.
But there are plenty of options to make the kit a little better.
I too have the Kawahara Pinions*/Brake Disc*/Rear Sway Bar* also the Square ti rear dog bones and drive cups, Evola Springs, 2 kit rear shock towers glued together to reduce flex and a 5th body post.
They were not needed but they do help make the car easier to drive.
*not yet run
NiMo is offline   Reply With Quote
Old 07-11-2005, 08:54 AM   #3303
jrabbito's Avatar
Very True NiMo,
Just in case he wanted hop ups thought we could lead him in the right direction so he doesn't spend money on useless cosmetic only upgrades.
Very good clarification though.
Cheers,
John
Old 07-11-2005, 09:02 AM   #3304
just curious if anyone else noticed this. i have the World Edition car and the ti 2 speed shaft (kyosho) and the ti middle shaft (3 racing. also have the ti bevel shafts for the diff. everything else is stock... and my car weighed in at 1770. i thought this car was underweight. also, have the lightweight gear housing from 3 racing.
Originally Posted by jrabbito
Very True NiMo,
Cheers,
John
Joe Chaplow is offline   Reply With Quote
Old 07-11-2005, 09:18 AM   #3305
ziggy12345's Avatar
I have the AAA battery pack also and it weighs in at 1750 grms
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-11-2005, 09:59 AM   #3306
Is anybody going to the nationals in texas with this car. If so would please share your set-up
breese is offline   Reply With Quote
Old 07-11-2005, 10:01 AM   #3307
Francis M.'s Avatar
I have the standard kit and added ti screws including diff screws and ti turnbuckles. my cars dry weight with body is 1730. So i took out the Ti screws from under the chassis and put the steal screws wich added to 10g so I can have an bigger gap from roar min weight of 1725 to factor in tire wear. Ive noticed that the WC actually has heavier pivot balls than the standard kit.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-11-2005, 10:25 AM   #3308
jeffreylin's Avatar
R/C Tech Charter Subscriber
Really? Dry with body and tires? One of mine has steel screws and I still have to add 10g to make legal weight.
jeffreylin is offline   Reply With Quote
Old 07-11-2005, 10:46 AM   #3309
Trader Rating: 26 (100%+)
Default Build tips
I just purchased a WC kit. Any tips on the initial build that I need to be aware of. Built both diffs and the servo saver so far, only problem I have found is trying to figure out which screws go where. Drawings are close to the actual sizes, but may need to buy a caliper to make sure I am using the right ones. Also is the 30,000 oil the way to go in the rear diff? I will be running at Revelations in Montclair,CA.
svines1972 is offline   Reply With Quote
Old 07-11-2005, 10:49 AM   #3310
jeffreylin's Avatar
30k works good at Revelation most of the time.
Old 07-11-2005, 10:58 AM   #3311
yeah, the weight was with the body and tires. one thing i have changed is that i had the 3 racing rear aluminum bulk covers on it. i took them off and put the stock plastic on. so i am guessing my car should be around 1755 now. i didnt have a scale available to measure the difference. i was not aware that the WC edition pivot balls weighed more. i have to check that out, and might replace. but, i think i am comfortable with the car weighing 1755. that is with tires that are 62/60mm. probably, i will be runnin at 60/58 in my qualifiers, so that should bring me down to 1750... which is only 25mm above.
i have had the regular kit and now the world edition. for whatever reason the world edition seems so much nicer. i guess it might be the belts, it is very free flowing and very little resistance. even the plastics seem to fit a little better. maybe thats because i had one of the first rrr out there.
Old 07-11-2005, 11:21 AM   #3312
mcsquish's Avatar
Any tricks on keeping the read diff from leaking? I was told to glue it, but I was wondering if there were any other tricks.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 07-11-2005, 11:42 AM   #3313
Jeffreylin, any other tips or upgrades I might need before I build it?
Old 07-11-2005, 11:55 AM   #3314
Francis M.'s Avatar
i would just build it per instruction. The box set up is a good starting point.
The one thing that is a must is a thicker rear shock tower. I'm not sure if the w/c already comes with one. If not Skylineracing makes a good one.
Old 07-11-2005, 11:59 AM   #3315
jeffreylin's Avatar
The diff shouldn't leak if you built it per instruction. One thing that was not clear in the instruction is how much diff oil you should put in it. I have them just slightly covering the bevel shaft or perhaps 60-70 percent full. If you fill it to the top there will be too much oil inside and it will leak and your diff won't work right.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
