Old 07-05-2005, 11:15 AM   #3256
ziggy12345's Avatar
Originally Posted by Rob Phillips
Amyone having any problems getting any rear droop with this car? The shocks seem to be a little short on the rear. Is there any longer K shafts that will make the shocks a little longer. Thinking of putting some xray shocks on it.
What are you guys doing to put a spool or a diff in the front.
If you put the roll inserts in so that the pivot hole is at the bottom at the rear you wont get much droop
I use the highest setting but then dont use any droop as it gives traction roll
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 07-05-2005, 11:49 AM   #3257
NiMo's Avatar
I've gone the other way
I'm using the lowest hole and 2 degree toe in with 2 degree camber, also have the shocks laid down with green 1.9 rears.
Using this I have got the V1RRR to have almost as much rear grip than the FW05, but I now have a load more front on power grip, all this with GQ 42's when the FW05 needed 37's.
NiMo is offline   Reply With Quote
Old 07-05-2005, 11:53 AM   #3258
ziggy12345's Avatar
Thats the setup i used at Aldershot. It dont work at Ashby. The car darts about like a drunken terrier unless you raise the roll centre. What about roll bars? I dont use one at the back and have the front full on and am using the FW front one thats a lot thicker than the RRR one.
Cheers
Sponsored by:
Norfolk and Chance
Old 07-05-2005, 02:41 PM   #3259
Do you guys need to cut off some of the sponge at the front of the car to accomodate the BODY SHELL?
Cause i have HPI GTR R34 and a Mazda RX-8 body shell and it fits perfect everywhere except for the sponge in front which is too wide.
I am getting the Protoform Mazda 6 soon and does the mazda 6 fits perfectly?
Tiger266
tiger266 is offline   Reply With Quote
Old 07-05-2005, 02:51 PM   #3260
Trader Rating: 49 (100%+)
you will need to shave the front bumper down some to fit the Mazda 6 body.
rodneybarrett is offline   Reply With Quote
Old 07-05-2005, 03:54 PM   #3261
Unhappy Tire Wear
What kind of tire wear do you have with this setup? I am running 35's in the rear and I am having excessive tire wear. Could be my driving though...
XrayEye is offline   Reply With Quote
Old 07-05-2005, 03:59 PM   #3262
Send a message via ICQ to piorc
Default Front solid axle
Hi guys, i need to put the front solid axle on my rrr, but i noticed that the opcional part that blocks the diff just broken.
What u guys do??
some body runs solid axle?? which part do u use?
Thanks.
piorc is offline   Reply With Quote
Old 07-05-2005, 06:41 PM   #3263
I purchased a 3racing V1RRR bumper which will fit the mazda 6 body.
silverM3 is offline   Reply With Quote
Old 07-05-2005, 06:58 PM   #3264
Trader Rating: 19 (100%+)
What u guys do??
Thanks.
3racing makes one out of aluminum that should be considerably stronger.
sjr456 is offline   Reply With Quote
Old 07-05-2005, 08:30 PM   #3265
AndyT 's Avatar
Yep, the 3-Racing solid axle adaptor is the way to go if you plan on running a solid front diff....the plastic block will eventually strip.
AndyT  is offline   Reply With Quote
Old 07-05-2005, 09:40 PM   #3266
Vince's Avatar
this may have been asked before but what is the difference between the 0 deg knuckles and the 2deg knuckles? which one gives more steering?
Wallace Motorsports
WRC
Murnan Modified Motors
VP Fuel
Hot Race Tires
Vince is offline   Reply With Quote
Old 07-05-2005, 10:03 PM   #3267
Francis M.'s Avatar
The 0 deg should be more responsive and the 2 degree will be smoother coming in to the turn and should give more exit steering.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-06-2005, 01:53 AM   #3268
ziggy12345's Avatar
The diff and look is too heavy. The guys here get a one way spool and push out the bearings then lock the outdrives in the spool with a collet. Its about half the weight and you dont have the problem of the steering linkage hitting the diff case
Sponsored by:
Norfolk and Chance
Old 07-06-2005, 08:46 AM   #3269
NiMo's Avatar
Cheers
Kit one used on rear and front
front vertical (stiffest)
Old 07-06-2005, 08:48 AM   #3270
NiMo's Avatar
Go harder !!!
I found the RRR undrivable on 35's, loose on 37's, good on 40's, better on 42's.
Also the harder you can run then less tyre wear you get.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
