Old 10-19-2004, 09:12 AM   #301
sonik's Avatar
Send a message via MSN to sonik
Default trinity reflex nt clutch bell
hi , dont know if this is the right place to ask ? i have bent my 2speed clutch housing holding it with mole grips trying to get the gears off , i have ask'd my lhs for price of replacement and the say the trinity one is 50 quid and has to be ordered , i want to know if the kyosho v1rr/rrr clutch bell will fit my trinity ? , almost everything else does, and i can probably get this from shop down the road,
thanks for any help on this
sonik
sonik is offline   Reply With Quote
Old 10-19-2004, 04:28 PM   #302
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally posted by BrainTeased
thanks for the clarification dameetz
may i also ask if its possible to use a fw-05R clutch on the RRR im thinking about the RRR but i just purchased a new FW-05R clutch and dont wanna waste it.
The RRR also comes with the gray clutch shoe instead of the black.
You can use the FW clutch as long as you switch out the clutchbell and the approriate pinions. The only difference you should be aware of is the clutch spring. Since it's different, the adj. nut setting will not transfer over. The 4D spring included with the RRR does not need as much tension as the 3D spring.
I drove the car with my FW clutch and just changed out the clutchbell with no problems.
Racing4Evo is offline   Reply With Quote
Old 10-19-2004, 08:55 PM   #303
me too. I changed clutches between the fw and rrr no problems just set for proper engagement and you are good to go!
rcosmax is offline   Reply With Quote
Old 10-20-2004, 03:50 AM   #304
BrainTeased's Avatar
thanks guys!!!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-20-2004, 08:24 AM   #305
sonik's Avatar
Default Re: trinity reflex nt clutch bell
sonik
no help for rookies ??
Old 10-20-2004, 08:37 AM   #306
NiMo's Avatar
Default Re: Re: trinity reflex nt clutch bell
Wrong place to ask, try the Trinity forum.
NiMo is offline   Reply With Quote
Old 10-21-2004, 12:10 PM   #307
Sow&Steady's Avatar
UPDATE!
Folks, the full editorial and race report by Mike Meyers is now available in the Contents section of 3hobby.com!
Check it out!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-21-2004, 04:01 PM   #308
kemy's Avatar
Default Just came back
from my LHS and YEEEEEEEEEES I bought an RRR !! I was going to get the Fw 05R first since I heared it's easier to drive and I'm not that professional, anyways I couldn't resist the quality and bought one!! I got it for $ 385 which is excellent considering I'm living in Kuwait.
Still didn't get a body or an Engine yet since the LHS doesn't have the Novarossi 5 ports until another 3 weeks.
I just wanted to share my excitement with you guys since you helped me a lot in making my decision by reading all your posts, also if you think i should know any tips or hints during building the kit please let me know.
peace
kemy is offline   Reply With Quote
Old 10-21-2004, 07:22 PM   #309
the only tip or hint that will really help you is to make sure that the sus arms have free movement. If there is binding take a 3mm drill bit and run it through both holes on the sus arms at the same time to line the holes up perfectly, reassemble and check and repeat if needed. Do a little at a time and check to avoid taking out too much material. Also set the front and rear belts on the loose tension setting and they will run in smoothly.
Have fun and congrats on buying the World champion touring car!
Old 10-22-2004, 06:07 AM   #310
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
rcosmax: Do you race in Japan?What are the winning engine in Japan?
suntok2 is offline   Reply With Quote
Old 10-23-2004, 03:43 AM   #311
kemy's Avatar
Thanks Max....I actually almost done and set the tension to medium, do u think it's worth the hassle of going back and setting to loose ? also , what engine do u recommend ?
Old 10-24-2004, 02:58 AM   #312
Team-RTR's Avatar
have you guys tried the fton spool diff? is it suited to a medium sized track? and does anyone have a setup for a medium sized track?
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 10-24-2004, 03:53 AM   #313
ziggy12345's Avatar
Does everybody user the kit setup such as front shock pistons with one hole and 500 wt oil?
I will build mine exactly like the kit and see what I need to change. I dont run a rear roll bar usually
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-24-2004, 04:35 AM   #314
rjl
rjl's Avatar
Ziggy, I would build the car exactly as per the instructions including the rear bar, run the car on foam and keep us informed.
rjl is offline   Reply With Quote
Old 10-24-2004, 09:37 AM   #315
ziggy12345's Avatar
There are a number of options not noted in the instructions. It shows the one way so I'll use that but what servo saver do you use? I used the middle one, 11 i think
Also what position for the inserts on the suspention? I used B High for all inserts.
The only other option was the rear upper camber link. It shows using ball ends in the instructions but there is an alternative that looks like the V-one-RR rear links. There are no inserts for it so I ordered some 6x3x2.5 bearings to go inside. I also changed the servo saver inserts for 10x6x3 bearings
Do they make CVJ's for this yet? I cant stand dogbones!
Has anybody had any trouble with the rear belt hiting the deck? It almost sticks out below the chasis! (G4!)
Cheers
Sponsored by:
Norfolk and Chance
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
