Old 06-17-2005, 12:12 PM   #3031
kidDynomite's Avatar
Default RR Evo tire wear Q:
Don't mean to bring this up on the RRR thread, but I race my RR Evo last weekend and noticed the rear tires wore faster than the fronts. I've got the 25T side pulley on it. I'm just wondering if anyone remembers what side pulley slows down the front vs rear tire wear. Or should I just cut my fronts down 2mm smaller, like on the RRR?
kidDynomite is offline   Reply With Quote
Old 06-17-2005, 12:57 PM   #3032
kewdawg's Avatar
Originally Posted by ROBBIE C
Customize you charger with a Designs By Bahnatka faceplate----->Designs By Bahnatka
You ever think about customiving starter boxes?
click on the link to ask that question or "pm" steve, here on rctech. He hangs out in the Xray FT 05', eXpress motosports and 2005 eXpress Paved On-road Championship threads.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 06-17-2005, 01:01 PM   #3033
kewdawg's Avatar
I believe you're talking about the "Fast Gear" option, which includes the 24T pulley and 384 or 387 belt (not sure, which one? ).
Quinn Moon
Old 06-17-2005, 02:29 PM   #3034
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Best clutch settings
Jeffery ,nimo ,D ,im will running a parlmaris comp, Top12 3port with stock spring for now got a race on sunday ,short track straightaway about 150 feet.will stock settings be fine i like to run my fwo clutch tight.So help is need
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 06-17-2005, 02:36 PM   #3035
kewdawg's Avatar
On a 150 ft. straight, back the two speed screws out one full turn from the stock setting.
Quinn Moon
Old 06-17-2005, 03:09 PM   #3036
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
Thanks I'll try that.
ROBBIE C is offline   Reply With Quote
Old 06-17-2005, 03:45 PM   #3037
mugenextreme's Avatar
just wondering folks what difference is there in the v-one rrr standard and the WC kit parts wise. If this was posted before can someone post a link for me . cheers
mugenextreme is offline   Reply With Quote
Old 06-17-2005, 07:59 PM   #3038
Rob Phillips's Avatar
you found the link, just look back.
I think if you would look back a few pages, you should find info relating to that since that is what everyone wants to know about a updated kit.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 06-17-2005, 08:02 PM   #3039
Any suggestions for a pipe. I was thinking about a RD Logics pipe, or maybe a RB pipe to run on my MT-12 and soon to be, Sirio Evo 3.
Anyone tried the new RD pipe with the "waller" adapter included with it?
Old 06-17-2005, 08:17 PM   #3040
jeffreylin's Avatar
R/C Tech Charter Subscriber
Try the Skyline pipe. That's what all the fast guys are running.
jeffreylin is offline   Reply With Quote
Old 06-18-2005, 12:28 AM   #3041
AndyT 's Avatar
A few older V-one parts were made by Kawahara. Like engine mounts. I've been using a few of their parts since the V-One R/RR. To me, their quality is way better than 3-racing. 3-racing chassiss are thick but made with soft alum. and tweak very easily. Some of their drive train parts are also weak and heavy. 3-racing Ti parts are also crap. Although, for some reason the Kawahara plastic parts on my FW/ZT1 have become brittle. I had someone CNC new parts for me. But the best thing to do is keep with Kyosho parts as much as possibe. I would concider Skyline hop-ups. Stay away from alum. pulleys. They wear 10x faster than the stock ones and end up chewing up belts.
My best source for Kawahara parts are through RC Champs. If they don't have them in stock, they'll get them for you. No one from Kawahara ever replies back to me, I guess none of them speak much english.
Kyosho seen to be making a lot of the hop-up/lightweight parts for the RRR now, so I`d be going with their parts before I`d get the 3-Racing ones.
East are also making Ti parts (shafts etc) but i havent tried them as yet so cant comment on their quality.
One East racing part i have tried is the rear carbon shock mount.....its okay but one thing I`m not overly keen on is how the upper shock mount holes all join in together.....this makes it very hard (especially if your wear glasses) to see which hole youve mounted the shock into.
This mount also has a little more bracing in the middle section to strengthen it.
Other than this its much the same quality as the 3-Racing & stock Kyosho rear mounts.
One part I`m very impressed with the quality of, is the Kyosho Team Shimo engine mount.....it offers much better bracing (its about twice the thickness) than the 3-Racing engine mount....and seems to have a much better tolerance on the threads for the underside screws than the 3-racing mount.
Cheers
AndyT  is offline   Reply With Quote
Old 06-18-2005, 01:37 AM   #3042
uaerc's Avatar
hi
Just got my rrr dialed in this weekend, after a long time managed to get it just right for our track handlingwise, had changed the rear oil to 3000 and put in some soft spring at the rear.
Unfortunately, some one hit my rrr on the exhaust and totally damanged my brand new rd logics turbo 2. Is there any way i could repair it ?? the stinger is crushed and squashed the whole front.
Had to put in the 7.2 mm skyline pipe in coz thats what i had as a spare, which i think only has top end. and my track is tight so you guys can imagine.......what would be the best pipe ? for My sirio 12 tup
Appreciate if someone can let me know how to setup my clutch as it is engaging really slow. is this standard with the RRR or i just need to change to the red shoe ?
the setting was done by a freind of mine who did it as per manual.
uaerc is offline   Reply With Quote
Old 06-18-2005, 08:07 AM   #3043
kewdawg's Avatar
Originally Posted by uaerc
hi
The Skyline pipe should be fine. Is the engine reving way up before the car moves or is the car just sluggish once the clutch engages (car begins to move)?
Quinn Moon
Old 06-18-2005, 08:14 AM   #3044
Suspended
Default my v1rrr here.
just play today and just found out that evo2 are great engine for v1rrr...
NaNa is offline   Reply With Quote
Old 06-18-2005, 09:40 AM   #3045
Default also ran my rrr today
the car has superfast accel. an a mean topend the car is really easy to drive an super aggressive . im sold can wait to get on a big track an become someones nightmare the spool work great my buddy abner made me 1 out of a oneway from the v1r.
RoninRc.com
Basher BT-4
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
