Old 10-18-2004, 02:53 AM   #286
InitialD's Avatar
Originally posted by markp27
No it was the button to send to Mark's house!!!!
Hopefully that's not the same button to charge into Mark's CC also.
Old 10-18-2004, 03:07 AM   #287
markp27's Avatar
Send a message via ICQ to markp27
Good thinking, D...I'll check
markp27 is offline   Reply With Quote
Old 10-18-2004, 03:41 AM   #288
rcabj's Avatar
Default front ?
anyone know what the rrr drivers were using in the front...one way/ front diff.???? thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 10-18-2004, 03:52 AM   #289
Default Re: front ?
Hi,
Josh was running a diff up front.
See the pic
Bye Thomas
840918001 is offline   Reply With Quote
Old 10-18-2004, 04:50 AM   #290
dameetz's Avatar
Default Re: Re: front ?
Originally posted by 840918001
Hi,
See the pic
Bye Thomas
I think its a solid (spool) up front. I read on mytsn that team Serpent wanted to try spool at front and mention that Kyosho team used it during the worlds.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 10-18-2004, 05:57 AM   #291
Default Re: Re: Re: front ?
Hi,
I gues you're right.
But if you look at the cars of Josh and Bertin, you see a diff I gues.
Why would they make a front axle that shape? I thought that the lower the rotating mass is the higher the acceleration and top speed will be.
What brand and kind of tires did the Kyosho team run?
Thanks and bye Thomas
Old 10-18-2004, 06:15 AM   #292
NiMo's Avatar
Originally posted by Sow&Steady
Careful with ordering from outside the EC ... might get taxed. Then again ... NiMo, your got in a bunch of FW05s without tax right? How did you do it?
Anything from America is Customs charged, even DVD's.
From Hong Kong I've only had two things charged, and both was from RC-Union. The other 50 or so deliveries had no charge.
NiMo is offline   Reply With Quote
Old 10-18-2004, 09:22 AM   #293
Joehwee's Avatar
They could be running a spool cos V1RRR come with a plastic insert to lock the diff.
HB Racing - OS Engine - VP Powermaster - Nosram - Sanwa - Schumacher Racing - HPI Racing - CapricornRC - Dualsky - Savox - AKA - Juc Racing - Team Orion - SMJ - MM Spec - Muchmore Racing
Joehwee is offline   Reply With Quote
Old 10-18-2004, 12:13 PM   #294
How?
The kit is coming with a one way!
I haven't seen the locking part in the kit
Thomas
Old 10-18-2004, 12:37 PM   #295
i believe that 3racing do an alloy block to fit inside the front diff too lock it up.
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 10-18-2004, 08:14 PM   #296
Joehwee's Avatar
840918001: Yes, the V1RRR come with an one-way, but it also come with the front diff case, the plastic insert for locking the front or rear diff. Take a good look at those extra plastic parts remaining you will find it there.
Old 10-19-2004, 12:08 AM   #297
Team-RTR's Avatar
drove my RRR last weekend. all i can say is wooowie!! i am loving it! i found that at about 57mm front 60mm rear the car is quite easy to drive and is not as taily. i also moved the rear springs down to blacks and set the front rollbar to about 45 degrees. i have never driven a faster car then this. good job kyosho on such a great tourer!
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 10-19-2004, 05:31 AM   #298
BrainTeased's Avatar
so you dont like your LD3 anymore Todd?
also todd can you check your clutch on the RRR for me and tell me if its the same as the VoneRR evo clutch.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-19-2004, 06:51 AM   #299
dameetz's Avatar
The working system is similar to EVO except for the flywheel (small diameter as FW), the clutch bell (which is also smaller) and the clutch spring included is 4D type, I guess this one come from Fantom/Evolva clutch spring.
Old 10-19-2004, 06:57 AM   #300
thanks for the clarification dameetz
may i also ask if its possible to use a fw-05R clutch on the RRR im thinking about the RRR but i just purchased a new FW-05R clutch and dont wanna waste it.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
