Kyosho v-one rrr
#2971
Originally Posted by jeffreylin
I think if I was to get into 1/8 scale I'd get a Evolva 2005 since some parts are interchangeable and everyone who has or had one loves it.
#2973
jwfFrani-I think I'll also give the 1 deg. hubs a try next week and see if the car feels better. Where were you? You made the A main.
#2975
Can anybody tell me if the 3racing rear swing arm 007A has a 2mm offset for the RRR?
Cheers
Cheers
#2976
extended bumper
guys,
does kyosho already have an extended front plastic bumper (lola-type, similar to the V1rr Evo) for the RRR? I doubt the one for the RR Evo would fit ( i could be wrong). anyone know if the evolva plastic bumper would fit?
Thanks in advance!
Thanks in advance!
#2977
The Evo one only fits on the middle screw and thats how I run it. I havent had any problems with it like this
The evolva one is too big
Cheers
Cheers
#2978
Originally Posted by jwf_frani
just finished running my car with the 1 deg steering blocks and the car is finally pretty smooth to drive with a one way.
#2979
Originally Posted by kidDynomite
jwf_frani, what part of handling does the 1 degree hubs smoothen out? I notice that the 0* seems pretty aggressive on mid to exit. Not so good on power. I'm also running a one-way.
#2980
#2982
you got it right joe mugen. It has better steering on power. or exiting the turns.
#2983
Originally Posted by doki_doki
huh??? that wierd i have an os .12tz 5 ports engine and it came with a p6 turbo plug. did you change the inner head of the engine??? the a5 plug is a standard plug. it won't fit the inner head of the .12tz since it has a turbo inner head...try to check you engine...
#2984
the 1 deg trailing block seems to smooth out entry and doesn't seem to square up the car coming in and it does help with on power steering.
#2985
Cheers
Cheers
thanks for the reply ziggy. however, you said only the middle screw fits. so would it like missalign itself much?
thanks!
