Old 06-09-2005, 10:28 AM   #2926
ziggy12345's Avatar
Originally Posted by jeffreylin
I just installed the new chassis. It is stiffer but mostly longitudinally. Installing the battery was a pain but you can move your battery slightly left to acheive a better weight balance. I don't think it will affect the handling much but we will know for sure after this weekend's race.
Is that the new 7075 from Kyosho or the 4mm one?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-09-2005, 10:31 AM   #2927
jeffreylin's Avatar
R/C Tech Charter Subscriber
Cheers
the new 7075 from kyosho.
jeffreylin is offline   Reply With Quote
Old 06-09-2005, 10:34 AM   #2928
ziggy12345's Avatar
Stiffer chassis on the RRR means less grip. Let me know how you find it. I heard somebody is making a 2.5mm one?
Cheers
Sponsored by:
Norfolk and Chance
Old 06-10-2005, 11:52 PM   #2929
markp27's Avatar
Send a message via ICQ to markp27
You guys ever had interference problems with your RRR? I have massive interference - can't drive the car because of it. I changed the Rx, the battery, different crystals, tried putting a capacitor over the power rails - nothing helped How do you run your cables?
markp27 is offline   Reply With Quote
Old 06-11-2005, 01:09 AM   #2930
NiMo's Avatar
I've had a few times when it appears to flick the power when it should be off power and it has sent me off the track, but I thought it might have been the bumps.
It only happened on race day when we had a full house on the rostrum, I had to move to another spot to cure it, and I was the only one on 27mhz (FM), the rest were on 40mhz.
I was thinking on changing the KO RX to a Futaba.
NiMo is offline   Reply With Quote
Old 06-11-2005, 01:21 AM   #2931
TRAJ's Avatar
I havnt had any probs with my futaba system
I keep the wires in between the fuel tank and the throttle servo
TRAJ is offline   Reply With Quote
Old 06-11-2005, 01:37 AM   #2932
markp27's Avatar
I really noticed a lot of interference when I touch the chassis or engine with a metal screwdriver - I don't understand where this is coming from - pretty frustrating
All my gear including the crystals is Futaba.
Old 06-11-2005, 02:32 AM   #2933
stefan's Avatar
Send a message via AIM to stefan
Mark,
are you going to the LRP TCM next weekend in Lux.?
stefan is offline   Reply With Quote
Old 06-11-2005, 02:58 AM   #2934
markp27's Avatar
Originally Posted by stefan
Mark,
Unfortunately not, Stefan I would have liked to have gone, but I have an SM-Lauf in Asbach on that weekend and seeing as I want to qualify for the DM in Berlin, it's better that I do Asbach.
I think a couple of other guys from Pro8 are going though.
Are you going?
Cheers, Mark.
Old 06-11-2005, 03:03 AM   #2935
kidDynomite's Avatar
Mark, might be metal-to-metal noise.
Try check the not-so-obvious: Once on my Evo, a front swaybar blade came loose and was not quite meshing right with the other, check to see that your brake disk isn't chattering on the brake holder or agains the carb, look at you universals to see if the pins are secured in the pivot section, or that you have o-rings or fuel tubing in the outdrives/dogbone/axles, double check you Tx antenna is tightened, make sure there are no cut or exposed wires, sometimes servos are the problem especially if it has metal gears, check your muffler stay is secured, clutch bell bearings are still in tack especially metal sheilded ones. These are just some of the thinks I can think of from past experiences.
kidDynomite is offline   Reply With Quote
Old 06-11-2005, 03:21 AM   #2936
markp27's Avatar
Will do - thanks for the tips.
Cheers, Mark.
Old 06-11-2005, 03:49 AM   #2937
stefan's Avatar
Are you going?
Cheers, Mark.
Yep,
leaving Friday morning, very early
Stefan
Old 06-11-2005, 04:33 AM   #2938
jeffreylin's Avatar
Mark, also check if any of your wires are exposed and touching the chassis.
Old 06-11-2005, 06:14 AM   #2939
i had this same thing happen to me once, but it turned out the transmitter battery was low.
Joe Chaplow is offline   Reply With Quote
Old 06-11-2005, 06:16 AM   #2940
also, make sure the receiver is loose. do not tighten it up so it is stiffly planted.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
