Old 06-08-2005, 08:27 PM   #2911
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by rcrossco_1
Ive got a question for you guys.
When mounting the rear roll bar, did you use the plastic washer things that had a peg shape on the bottom?
Ive used mine, but they dont seem to be 100% flat when holding in the 2mm roll bar.
Just wondered what the purpose of them was. Maybe the small peg on the bottom is meant to only just touch the roll bar with the smallest possible surface contact?
God knows.
Rossco
You must use it for roll bars 2mm and smaller. It may not sit flat but that does not matter. The small peg is meant to touch the roll bar slightly without causing bind. The purpose is so that there is no slop in the anti-roll action. you can check by taking the rear shocks off and see if lifting one of the wheels will lift the other almost immediately. If it does not then the anti-roll bar is not installed properly. Check from both sides to ensure the actions are even.
jeffreylin is offline   Reply With Quote
Old 06-08-2005, 08:32 PM   #2912
jeffreylin's Avatar
Originally Posted by Joehwee
Jeff: I was told the material are the same, you may find it stiffer becos there are no cutout for the batt.
I will take out the old chassis today and compare. I know the cut out makes a difference but the new chassis just seem that much more stiffer. Have you tried your car with the new chassis? Can you tell the difference.
I also got the titanium 2 speed shaft last night and for $15 or so it seems to be a very good upgrade. I will compare the weight between the ti shaft and the stock one tonight and post the result here.
Old 06-08-2005, 11:09 PM   #2913
AndyT 's Avatar
Originally Posted by khyber
I am in the midst of building my V1RRR then I stumble on this thrust bearing installation. Does anyone know whether there is orientation to the thrust bearing since both surface are in different shape. Which side is facing engine ?? Pls help
Dont forget after each race meet to give the clutch bearings a good clean/lube and check their condition as well.
If the front/rear clutch bearings fail, the metal shards will make a mess of your thrust bearing
I use Trinity Royal Oil to lube the bearings and have found this to work quite well.......another racer recommended to use Mugen Super Grease on the thrust bearing with which he`s been very pleased.
Cheers
AndyT  is offline   Reply With Quote
Old 06-09-2005, 04:40 AM   #2914
jeffreylin's Avatar
Default Titanium 2 speed shaft
Stock steel 2 speed shaft = 20g
Titanium 2 speed ahft = 12g
That's a big difference in rotating mass.
Old 06-09-2005, 05:00 AM   #2915
Grinder's Avatar
Keep an eye on the Ti shaft. Mine wore out very quickly.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 06-09-2005, 05:20 AM   #2916
jeffreylin's Avatar
The new Kyosho one? I know 3Racing has one too but Kyosho one should be better. I used a Square Ti shaft in my FW05R and that thing hardly wears at all.
Old 06-09-2005, 05:38 AM   #2917
TRAJ's Avatar
Is the Ti Kyosho shaft available yet or is there and estimated date?
TRAJ is offline   Reply With Quote
Old 06-09-2005, 06:19 AM   #2918
jeffreylin's Avatar
I bought it from Hong Kong so it's available.
Old 06-09-2005, 06:21 AM   #2919
TRAJ's Avatar
Oh is it.. Thanks
Old 06-09-2005, 06:32 AM   #2920
what wears on the ti shaft? how can you tell if your shaft has been worn out? i have had the 3 racing for some time now, and it seems to be fine.
Joe Chaplow is offline   Reply With Quote
Old 06-09-2005, 08:32 AM   #2921
Default Front gear diff
Can anybody recommend a good starting weight diff oil when running a front gear diff? We run mostly on tight tracks.
Thanks,
XrayEye is offline   Reply With Quote
Old 06-09-2005, 09:17 AM   #2922
10,000 Rear
30,000 front.
Works well on my local tight twisty track.
rcrossco_1 is offline   Reply With Quote
Old 06-09-2005, 09:46 AM   #2923
Grinder's Avatar
I had the pin holes wear and the part that 1st gear sits on siezed to the shaft. It also bent. It is the 3 racing shaft.
Old 06-09-2005, 10:01 AM   #2924
jeffreylin's Avatar
I just installed the new chassis. It is stiffer but mostly longitudinally. Installing the battery was a pain but you can move your battery slightly left to acheive a better weight balance. I don't think it will affect the handling much but we will know for sure after this weekend's race.
Old 06-09-2005, 10:05 AM   #2925
jeffreylin's Avatar
I think the stock steel one bends just as much if you hit it during a crash. I've been lucky but it seem many of my friend's RRRs have their shaft bent at least once.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
