Old 06-08-2005, 09:53 AM   #2896
ohh ok thanks. so its one set of 15t, 16t and 17t in the wc kit.
tiger266 is offline   Reply With Quote
Old 06-08-2005, 09:55 AM   #2897
NiMo's Avatar
Found a place to get the Kawahara parts for the RRR
http://www.rakuten.co.jp/rc-rainbow/...589761/#626115
But I cant see how to order from them (it's all Japanese)
NiMo is offline   Reply With Quote
Old 06-08-2005, 09:56 AM   #2898
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by Joehwee
The new chassis part number is VZW-214, the design and material are the same as the stock chassis but in gun metal, the only different is there is no cutout for the battery tray, the batt is mount directly onto the chassis.
rcosmax: I dun think the new chassis is available in US yet, I will be running it this weekend. Maybe we can both share our experience with the new chassis and post it here. I think the chassis should provide less flex, as there are not cut out for the batt tray and more suitable for high traction track. But I could be wrong.
hi joe are you sure the 7075 chassis is made of the same material as the stock chassis? i just got mine today in the mail and while i didn't put it on the car yet it does seem a lot stiffer than the stock chassis.
jeffreylin is offline   Reply With Quote
Old 06-08-2005, 09:58 AM   #2899
jeffreylin's Avatar
no it's 16T for first and 21T for second in the kit. 15T & 17T are optional ones that you purchase separately.
Old 06-08-2005, 10:01 AM   #2900
jeffreylin's Avatar
NiMo, you can order the Kawahara parts from Pro Shop Futaba or RC Champ too.
Old 06-08-2005, 10:21 AM   #2901
heya,
does the dogbone/universal swing shaft break easily?
does the app02-02 brake pad improve the braking by alot?
anyway how many times did u have to replace the belts? duration and amt.
and also erm beside the usual hubs, arms, shock towers, and rear diff joint. what else do u recommend to get to keep as spares or to improve the WC further. Do u recommend getting extra aluminium brake lever?
sorry that i am asking a lot of questions, but hey this is the forum and u guys are helpful form what i can see , anyway this is my first car and i am ordering from overseas (much more cheaper to order all at once) so i am just getting the spares together with the WC kit.
Old 06-08-2005, 10:29 AM   #2902
jeffreylin's Avatar
no but wears out over time maybe a gallon or 2.
that's what i hear
probably replace every gallon or two
yes on the brake lever
Old 06-08-2005, 10:31 AM   #2903
that's what i hear
Thanks alot jeff..
Tiger
Old 06-08-2005, 06:32 PM   #2904
Originally Posted by centax error!
can't seem to find part # for the rear universal swing shaft (0 mm offset). Kyosho or Aftermarket, anybody?
CE
I know 3 Racing makes them
silverM3 is offline   Reply With Quote
Old 06-08-2005, 06:58 PM   #2905
AndyT 's Avatar
You can greatly reduce wear on the dogbones by applying a small amount of black grease (ala teh Team Associated one) to the ends of them when you fit them.
You`ll find this really helps in reducing "notching" as well.
Cheers
AndyT  is offline   Reply With Quote
Old 06-08-2005, 07:56 PM   #2906
jeffreylin's Avatar
Cheers
Thanks Andy. It does help quite a bit. Nevertheless, mine still needs replacing on a regular basis. I do run my car quite a bit though. I would go through 1/2- a full gallon every race between practice, qualifying, and the long main (often 30-40 minutes).
Old 06-08-2005, 08:14 PM   #2907
khyber's Avatar
V1RRR Thrust bearing polarity
I am in the midst of building my V1RRR then I stumble on this thrust bearing installation. Does anyone know whether there is orientation to the thrust bearing since both surface are in different shape. Which side is facing engine ?? Pls help
khyber is offline   Reply With Quote
Old 06-08-2005, 08:18 PM   #2908
Doesnt matter.
Just make sure that you get the 4.8mm plate on the outside, and the 5mm one on the inside nearest the engine.
The metal cage is just to hold the balls in place and nothing else.
rcrossco_1 is offline   Reply With Quote
Old 06-08-2005, 08:20 PM   #2909
Ive got a question for you guys.
When mounting the rear roll bar, did you use the plastic washer things that had a peg shape on the bottom?
Ive used mine, but they dont seem to be 100% flat when holding in the 2mm roll bar.
Just wondered what the purpose of them was. Maybe the small peg on the bottom is meant to only just touch the roll bar with the smallest possible surface contact?
God knows.
Rossco
Old 06-08-2005, 08:22 PM   #2910
Joehwee's Avatar
Jeff: I was told the material are the same, you may find it stiffer becos there are no cutout for the batt.
HB Racing - OS Engine - VP Powermaster - Nosram - Sanwa - Schumacher Racing - HPI Racing - CapricornRC - Dualsky - Savox - AKA - Juc Racing - Team Orion - SMJ - MM Spec - Muchmore Racing
Joehwee is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
