Kyosho v-one rrr
Old 06-02-2005, 07:49 AM
  #2746
Originally Posted by 3434
does anyone know where to get the flywheel tool?
Joe Chaplow is offline
Old 06-02-2005, 07:52 AM
  #2747
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
jefferylin: this is what i'm referring to. thanks 3434
doki_doki is offline
Old 06-02-2005, 08:11 AM
  #2748
jeffreylin's Avatar
Call Kyosho America and see if you can get it from them direct (TSW008).
jeffreylin is offline
Old 06-02-2005, 08:13 AM
  #2749
thanks... do you have a recommendation on what turbo plug i should use in texas at the nationals. i imagine it would be very hot and humid.
Old 06-02-2005, 08:24 AM
  #2750
jeffreylin's Avatar
I was told to use c plugs for humid weather (over 70-80% humidity) and f otherwise. I had #7 working up to 100F but also try 8.
Old 06-02-2005, 08:25 AM
  #2751
thanks jeffreylin.
Old 06-02-2005, 08:54 AM
  #2752
What works great instead of the TSW-008 is a battery terminal puller for a full size car. You can pick them up at any auto parts store, even places like Kmart have them
3434 is offline
Old 06-02-2005, 11:05 AM
  #2753
apla's Avatar
Originally Posted by TRAJ
Typical greek language there doesnt make sense ohh sorry its TURKISH language
Anyone else help?
and you are supposed to be funny.....
apla is offline
Old 06-02-2005, 11:44 AM
  #2754
Trader Rating: 49 (100%+)
I need some dimensions please.
I am waiting on my diff parts but have a race this weekend where I don't think the one-way is going to do much good. So I want to try the spool. However, I have all piece except for the drive cups. I do have crive cups from the G4/mongoose but they are too long.
Can someone give me the following dimensions:
1) distance (mm) over entire drive cup (from end to end)
2) distance (mm) from the end of the outdrive cup to where you put the diff pin in.
This will allow me to cut the G4 drive cups and drill a new pin hole.
thanks.
rodneybarrett is offline
Old 06-02-2005, 12:25 PM
  #2755
Seisick's Avatar
guys, besides the stock rrr, the wc edition, is there also a wc limited edition that comes with additional pulleys, improved parts, etc that sells only in japan? and it's so limited that you have to register so you can only get one?
Seisick is offline
Old 06-02-2005, 01:10 PM
  #2756
NiMo's Avatar
thanks.
I have used the V-one R cups, they are 2mm too long in the shaft but I found on one of the RRR plastic trees some unused 2mm spacers which fitted with only marginal play, and it appears to be working, and makes the cups long enough for the drive shafts.
NiMo is offline
Old 06-02-2005, 05:11 PM
  #2757
jeffreylin's Avatar
I don't think so.
Old 06-02-2005, 08:54 PM
  #2758
Or you can go to an electronics surplus store to find a metal capacitor holder. It works for me.
silverM3 is offline
Old 06-02-2005, 09:07 PM
  #2759
Tim Johnson's Avatar
Is everyone starting to get there supply of needed Kyosho parts?
Tim Johnson is offline
Old 06-02-2005, 09:10 PM
  #2760
Racing4Evo's Avatar
Yes, Kyosho America has already shipped parts and kits to my LHS's a while ago.
Racing4Evo is offline
