Old 05-29-2005, 09:12 AM   #2686
NiMo's Avatar
Originally Posted by jeffreylin
I have the LSD kit but never tried it on the RRR. I tried on the FW05 and it made the car undrivable.
I also tried it on the FW05, it just made me crash too easily, and robbed a load of steering.
NiMo is offline   Reply With Quote
Old 05-29-2005, 05:14 PM   #2687
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
you can find a picture on the Kyosho website I think.
thanks...i'll check it out...
doki_doki is offline   Reply With Quote
Old 05-29-2005, 05:16 PM   #2688
AndyT 's Avatar
I use brake too and you can adjust it so that it's just enought to slow you down without spinning you out.
The ATL function on Futaba`s transmitters is a really excellent feature to fine-tune the brake when running a front one way....just dial in the % of brake according to track conditions
AndyT  is offline   Reply With Quote
Old 05-29-2005, 08:46 PM   #2689
when i make my rear shocks to the exact size of the manual, the shocks are too short and they pull the rear droop up some... now, when i make the shocks longer so that they do not pull the droop up, the ball cup is not screwed in too far. when i get into any kindof accident, the ball cup comes off the shock... has anyone had this problem??? what should i do?
Joe Chaplow is offline   Reply With Quote
Old 05-29-2005, 08:53 PM   #2690
jeffreylin's Avatar
R/C Tech Charter Subscriber
Make it like the manual. It's not too short. You don't need all that droop. My rear droop is set at 6-7mm from the bottom of the chassis measured at the hub.
jeffreylin is offline   Reply With Quote
Old 05-29-2005, 08:56 PM   #2691
the stock setup says to use 4... so i guess if i go to 6 i wont have a problem then. what kind of difference as far as performance will going from 4 to 6 do? thanks jeffreylin
Old 05-29-2005, 09:10 PM   #2692
jeffreylin's Avatar
Joe, I don't have the manul with me so I don't know where that 4 is measured from. Different points of measurement yields different reading of the same set up.
Also, did you check if you built the shock in the right length per manul? If you do you only screw in the ball cup half way. Use a caliper to measure the length of the shock.
Finally on the droop. I run relative small tires (generally 57/59) and 6-7mm gives plenty of droop. if you run bigger tires you probably need even less (as in 8-9mm). For a simple explaination on effects of droop setting, read the following:
http://www.donegal.flyer.co.uk/car%20setup%20guide.htm
Old 05-29-2005, 10:27 PM   #2693
jefferylin, thanks for your help.
Old 05-29-2005, 11:37 PM   #2694
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Default Sedan Body
Which sedan body do you guys recomend for this car??
Walter Diaz
wad is offline   Reply With Quote
Old 05-30-2005, 01:31 AM   #2695
NiMo's Avatar
the 4mm is measured at the unused roll bar mounts on the underside of the suspension arm.
If you want more droop then use the medium ball cups on the shocks, that should give you another 2/3mm.
Old 05-30-2005, 01:39 AM   #2696
jeffreylin's Avatar
I see. I don't use that because they have been destroyed long time ago
Old 05-30-2005, 03:35 AM   #2697
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Arrow
Protoform MAZDA 6 or the DODGE STRATUS 3
buboy28 is offline   Reply With Quote
Old 05-30-2005, 04:35 AM   #2698
Default ball bearings
I know there is an issue with many 3 racing parts, Has anyone tried their bearing set yet?
CHUCKMANDO is offline   Reply With Quote
Old 05-30-2005, 05:19 AM   #2699
NiMo's Avatar
Just been looking up the V-one S3 manual (pull-start version of RRR) and they appear to have a new style front spool which looks like the one-way unit.
Part number is VZ048 and should be priced around $5
Old 05-30-2005, 05:39 AM   #2700
AndyT 's Avatar
Yep the Protoform Mazda 6 is very good indeed....is the Dodge Stratus 3 released in 200mm?.....I`d only seen the 190mm.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
