Old 05-26-2005, 01:15 PM   #2641
Originally Posted by kidDynomite
Don't get me wrong, not all 3Racing parts are bad. But from my experience, some high-stress areas on the cars would rather call for stock or factory option parts. I use ti pillow balls in the back of all my Kyoshos, but stock pb in front. I try not to use third party alum. parts because they just add weight. After going through a bling-bling faze 3 yrs ago, I now just spend my money on spares, motors, fuel and tires. If you want any alumium upgrades, get the front swaybar holders (they keep better droop settings). Kyosho optional brake pads, Skyline rear shock tower and pipe support are some other "worthy" hop-ups.
does kyosho make the sway bar holders?....... another thing about 3racing stuff is that they never fit exactly the same as factory stuff does... i think this is because they do not have access to kyosho CAD designs. i do not know for sure, but they probably take the original and make the CAD from that... and this is probably why there is tiny discrpencies. this is just my theory on this and i may be completely wrong.
Joe Chaplow is offline   Reply With Quote
Old 05-26-2005, 01:18 PM   #2642
kewdawg's Avatar
Does anyone else, besides 3 Racing, make aluminum or titanium front sway bar holders for ther RRR?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-26-2005, 01:29 PM   #2643
kidDynomite's Avatar
No one make Ti sway bar holders. Just get the 3Racing alum. ones. A Kyosho sponsored racer told me that Kyosho gets them from 3Racing, otherwise known as the World Space Cad Industrial Company. I'm sure Kyosho thuroughly tests each 3Racing product to see what's worth their while to sell under the Kyosho name, so they don't have to machine the parts themselves.
kidDynomite is offline   Reply With Quote
Old 05-26-2005, 01:49 PM   #2644
kewdawg's Avatar
Will the aftermarket swaybar holders from past versions of the V-One R (RR, RR EVO) fit the RRR?
Quinn Moon
Old 05-26-2005, 02:20 PM   #2645
Data's Avatar
no, unfortunately (the one for EVO may fit thou)
Data is offline   Reply With Quote
Old 05-26-2005, 03:12 PM   #2646
If this is the case, that means 3 Racing's fitting should be ok. They must have CAD from Kyosho directly in order to manufacture parts for them.
JoeMugen, what are the parts from 3 Racing doesn't fit well with V1RRR?
silverM3 is offline   Reply With Quote
Old 05-26-2005, 03:26 PM   #2647
jeffreylin's Avatar
R/C Tech Charter Subscriber
I'm assuming the optional belt (387) is bigger, since the pulley is bigger by one tooth. I was thinking, since the stock belt is loose even with the belt tensioner half-way down, you could get away with just using the 24t pulley?
I think my friend tried that and it was too tight.
jeffreylin is offline   Reply With Quote
Old 05-26-2005, 03:28 PM   #2648
jeffreylin's Avatar
Originally Posted by rodneybarrett
Guys, what do you think about the Futaba S9550 low profile servo for steering on the RRR?
I was thinking of getting the s9451 but the specs are almost the same and I have a brand new s9550.
Also, still looking for suggestions on a throttle/brake servo. I am assuming non-digital, right?
I use KO2344 digital servo for throttle on both of my RRRs and never had a problem.
Old 05-26-2005, 03:32 PM   #2649
jeffreylin's Avatar
Originally Posted by silverM3
I also purchased my V1RRR WCE there(rc-toro). Very reasonable pricing (the lowest I can find in US
They also have Kyosho parts for V1RRR. And 3Racing parts for V1RRR. I really want to buy some 3 Racing and replace some plastic with titanium/aluminum. Is 3Racing parts really that bad?? Their price seems to be attractive.
I have not had very good experience with 3Racing stuff. I think they use lower grade material and tend to bend/break easily. If there is a Kyosho one I will always get the Kyosho hop up or just keep things stock. The only 3Racing upgrade I had on my car was the aluminum brake lever and I took that off as soon as Kyosho came out with one.
Old 05-26-2005, 06:23 PM   #2650
i havent tried any for the rrr... but i am not saying they don't fit properly, but i am saying they are just a hair off. i always got a little play with them... they just were not an exact match... but then again i am very picky.
Old 05-26-2005, 07:07 PM   #2651
on my first rrr, i bought aftermarket screws to build the kit... has anyone used the screws the kit came with... if so, how are they????
Old 05-26-2005, 07:33 PM   #2652
AndyT 's Avatar
I found the ones that came with the kit to be pretty good.
I bought a full set of aftermarket titanium screws as spares and in terms of quality i reckon the stock kit ones are better (much closer tolerances)
AndyT  is offline   Reply With Quote
Old 05-26-2005, 07:42 PM   #2653
AndyT 's Avatar
I`ve used a few 3-Racing parts on the RRR...some good, some not so...
The one piece engine mount seemed to have a poor tolerance on one of the underside mounting holes....some racers have mentioned it can warp...i havent experienced this though.
The l/w clutch bell has worked fine.
The rear diff housing has been fine.
The rear shock tower offers an additional shock position and a bit more bracing in the middle section than the stock one, but I`ve had one of these break....looks like its a 4mm one next for me
Old 05-26-2005, 07:56 PM   #2654
yeah, I also picked 2344. 2364 would have been better but more expensive.
This long weekend I will be 100% dedicated on putting the car together
Old 05-26-2005, 08:05 PM   #2655
Grinder's Avatar
I'm going to try the RRR with the engine and fuel tank 2mm lower.
www.murnanmodified.com
Grinder is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
