Old 05-23-2005, 07:28 PM   #2551
how did you get a 5% discount?
Joe Chaplow is offline   Reply With Quote
Old 05-23-2005, 07:29 PM   #2552
Originally Posted by silverM3
You can try rc-toro.com. I just purchased from them. I think they have pretty good prices, too. Good thing is they are in US. Just curious, why aren't there many shops in US carryng V1RRR? This car is the world champion car !!
Old 05-23-2005, 09:48 PM   #2553
Hey Joe Man
JOKERRACING is offline   Reply With Quote
Old 05-23-2005, 10:04 PM   #2554
I forgot. I told 3434 once. And, rodney should know it. why don't you contact them directly?
silverM3 is offline   Reply With Quote
Old 05-24-2005, 03:39 AM   #2555
AndyT 's Avatar
Originally Posted by rodneybarrett
After two long years fighting with my G4/mongoose(but with success), I have taken the plunge and have on order a V1RRR WCE (also from rc-toro).
Questions:
1) I run mostly on short tracks so what pinion/spur combinations do I need to get to have the best acceleration?
2) What if any breakage parts to order (not prone to wreck much but just want to be prepared)
3) What parts do I need to order to end up with a front diff. I understand that some of the parts I need are already in the kit.
4) Any aftermarket parts that help the car (not looking for bling).
5) Any build tips.
I should have it by end of week. I will be strapping on my new 12TZ and OS pipe
thanks.
1. Smaller pinion with a larger spur = more acceleration....the stock ones will work fine on short tracks, you can get a little more acceleration by running smaller diameter tyres.
2. The car is very durable but spares i carry are-
* Front and rear arms/hubs
* Shock towers front/rear
* Thrust bearing and both front & rear clutch bearings
* Hinge pins
* Belts
* Fuel tank
* Spur gears
* Ball ends/cups
Upgrades I`d recommend-
Rear shock tower
If theres pebbles at your track....get the aluminium rear diff case- I`ve had the stock one strip teeth due to stones
Aluminium pulleys....for same reason as above.
If youre after more performance consider-
Lightweight clutch bell
Titanium 2 speed & mid shafts
3. Diff info is on page 35 top left corner of the manual as to which parts to order for diff/spool
4.As above
5. Build tips-
Dont over tighten the fuel tank mounts
Brake calipers mount is wrong in manual....you`ll see though easily enough where the right holes are
When steering servo is centred, the horn mounts just to the left of top....say 1130 hours on a clock
Recommended clutch setting is too heavy....loosen it off
Two speed shifts best (depending on track) around 4 & 1/2 turns out to 4 & 3/4 turns out....not the 3 as recommended
Dont be surprised at the mid belt rubbing under the exhaust manifold....normal
Hope this helps
Cheers
AndyT  is offline   Reply With Quote
Old 05-24-2005, 03:46 AM   #2556
AndyT 's Avatar
Do you guys think that it is worth the money? If not, how do you setup/measure toe-in/out, camber, and etc?
Thx.
For accuracy you cant beat a good setup station, but you can get good results using a simple camber gauge and flat setup board/glass/etc.
This can be used for setting the camber angles......then stand the car on its rear and again use the camber gauge to set the rear toe-in as the car is vertical.......then with the car sitting normal again you can set the front toe out using the camber gauge and a straight edge ruler (not super accurate but will suffice till you get a setup station)
Cheers
Old 05-24-2005, 03:52 AM   #2557
AndyT 's Avatar
The US distribution was apparently handled by Great Planes and has now been taken over by Kyosho USA. I guess theyre still getting themselves sorted out??
Cheers
Old 05-24-2005, 04:54 AM   #2558
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
Originally Posted by joemugen
i sell a 4mm shock tower, brand new, carbon fiber $9.99 free shipping. i have sold many to people on this forum. it is very nice. email to [email protected]
Joemugen: you've got a PM!
Airwide is offline   Reply With Quote
Old 05-24-2005, 04:56 AM   #2559
[QUOTE=AndyT ]
Does Kyosho make the Ti parts? I think 3racing makes them but not sure of their quality.
CHUCKMANDO is offline   Reply With Quote
Old 05-24-2005, 05:20 AM   #2560
AndyT 's Avatar
[QUOTE=CHUCKMANDO]
3-racing make these, but they`re also made by East.
Cheers
Old 05-24-2005, 05:25 AM   #2561
AndyT 's Avatar
Oops, forgot, Kyosho make a lightweight clutch bell. I`ve used the 3-Racing l/w bell and it seems fine durability-wise. The 3-Racing bell is quite an open design and may tend to attract more dust/dirt into the clutch bearings than the closed Kyosho type, so may need more frequent cleaning/lubrication.
Old 05-24-2005, 06:43 AM   #2562
bulletdays's Avatar
Default Solid Differential
What is the effect of using the solid differential which is included in the WCE...
tnx in advance
bulletdays is offline   Reply With Quote
Old 05-24-2005, 06:51 AM   #2563
Originally Posted by JOKERRACING
Hey Joe Man
what's up joe. have not heard from you in a long time. how is everything going?
Old 05-24-2005, 07:52 AM   #2564
Trader Rating: 49 (100%+)
Thanks AndyT. I will take your advice on the parts and clutch settings.
Which is the best body to run? Mazda 6? Again, I mostly run on small tracks.
I have a stratus already painted without holes (actually, I have two). How do they work?
Last question. what is the best steering and throttle servo to use? I was using a 9550 in my G4 just because it fit better.
rodneybarrett is offline   Reply With Quote
Old 05-24-2005, 08:23 AM   #2565
my advice, the mazda 6 is the best body for this car. the stratus works good too. stay away from the caddy, it is way to agressive for this car and makes it very unstable. it is good for the 710 on some tracks because it adds to the steering whick you do not have with the rrr.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
