Kyosho v-one rrr
Old 05-21-2005, 02:54 PM
  #2521
NiMo's Avatar
I find it the other way around.
Anything I get from America always gets charged it's full value in customs duty, so basically I have to double the listed price, where as parts from HK only gets a charge now and then.
NiMo is offline
Old 05-22-2005, 09:52 PM
  #2522
buboy28's Avatar
Arrow
why not try sending them via FED-EX or DHL might be a little cheaper if they are coming from America
buboy28 is offline
Old 05-22-2005, 11:13 PM
  #2523
Tim Johnson's Avatar
Taxs........nooo more taxes...........LOL....anyone make it out to the RCX show and check out the Kyosho booth?
Tim Johnson is offline
  #2524
Thumbs up
I just ordered one V1RRR WCE from rc-toro this morning. And I got the tracking number tonite. (surprisingly, delivery companies open on Sunday Man, that is what I would call quality serivce!
silverM3 is offline
Old 05-23-2005, 06:04 AM
  #2525
Trader Rating: 49 (100%+)
Default Moved over to the Kyosho camp
After two long years fighting with my G4/mongoose(but with success), I have taken the plunge and have on order a V1RRR WCE (also from rc-toro).
Questions:
1) I run mostly on short tracks so what pinion/spur combinations do I need to get to have the best acceleration?
2) What if any breakage parts to order (not prone to wreck much but just want to be prepared)
3) What parts do I need to order to end up with a front diff. I understand that some of the parts I need are already in the kit.
4) Any aftermarket parts that help the car (not looking for bling).
5) Any build tips.
I should have it by end of week. I will be strapping on my new 12TZ and OS pipe
thanks.
rodneybarrett is offline
Old 05-23-2005, 06:50 AM
  #2526
bulletdays's Avatar
Default The effects of Solid Axle Differentials
Hi guys,
Anyone has an experience using the solid axle diff? whats the difference from one way and diff gear setup?
Thanks in advance...
bulletdays is offline
Old 05-23-2005, 06:56 AM
  #2527
Default rear shock tower brace
anyone heard of this rear shock tower brace??..made by kawahara racing...saw it in a japanese rc magazine...
cabworks is offline
Old 05-23-2005, 07:05 AM
  #2528
bulletdays's Avatar
Default rodneybarrett
- if you'll get the WCE then no need to change the gearing setup, im also running on a short track, and its fine...
- I think here you can find the part number www.kyosho.co.jp, but if you'll get the WCE, you just need the diff gears...
5) Any build tips.
- Just follow exactly whats in the manual and you're ready to go...
I hope this helps a little.
Old 05-23-2005, 07:28 AM
  #2529
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Questions:
---> you can try to chang the pinion to 15T/20T. keep the original spur that came with the kit.
---> so far, haven't broken any part of my rrr wce. i've had a collision on the strainght at full throttle with my rb rody v12 5 ports turbo engine and nothing was damaged except for the body. i've also been rear ended many times and nothing broke. i've flew off the track a couple of times and still nothing broke. this is a really tough car. just have a spare rear shock tower and belts.
---> i have posted the parts need including the part number a few pages back. check it out. all you need are the differential gears, drive cups, and the pin that holds the gears together.
---> i ordered the kyosho machined brake disc and i have yet to test it. so far, i have noticed some brake fade since i started running the kit. the wce comes with a stamped brake disc.
5) Any build tips.
---> just follow the manual. also, build the both rear and shock towers so as to save time. you can also try to mount the pipe holder on top of the chassis. it much easier to do but it does not look good but it does the job. when making the body holes, make sure that the rear post does not go under the wing. if it does, remove the rear mounts and attach it the other way around.
thanks.
hope i was able to help
doki_doki is offline
Old 05-23-2005, 07:29 AM
  #2530
doki_doki's Avatar
haven't heard of it yet. can you post a pic of the kawahara rear shock tower brace??? thanks
Old 05-23-2005, 08:51 AM
  #2531
ziggy12345's Avatar
Originally Posted by bulletdays
Hi to all,
Im planning to get a new Novarossi engine, can you advise me if you know some engine which is better than nova.
Thanks in advance.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MESE:IT
Nice modded engine
ziggy12345 is offline
Old 05-23-2005, 08:55 AM
  #2532
Hey Rodney,
Looks like we will be racing the same setup. Good, we can comapre notes!
XrayEye is offline
Old 05-23-2005, 09:21 AM
  #2533
Default More questions from the newbie
I read a few post back about the manual saying that the rear toe is set to 2 degree OUT. Typically, there is toe-in in the rear and so I have to ask again. Is this right?
Also, does anyone know if the G4/Mongoose Front diff will work. It is the same as the old reflex which had a lot of parts as the VoneR.
Old 05-23-2005, 09:26 AM
  #2534
Sow&Steady's Avatar
Originally Posted by ziggy12345
Sow&Steady is offline
Old 05-23-2005, 09:30 AM
  #2535
It is a typo, It is 2 in.
A few pages back is a linkn to the V one RRR WCE setup in english.
XrayEye is offline
