Old 05-19-2005, 05:03 PM   #2476
AndyT 's Avatar
Originally posted by ogreasurada
Whats the difference of using a solid instead of a diff? or one-way?
A solid has the same on-power characteristics as a one-way, but the solid offers the advantage of braking being applied to the front wheels when you need greater braking......good for tight tracks.
Off-power the one-way will offer better turn-in.
AndyT  is offline   Reply With Quote
Old 05-19-2005, 05:30 PM   #2477
So what off set wheels are U guys using for your RRR. I know Hot shoes makes an offset rear wheel. I have not seen an ellegi offset? Are there many choices?
PhatPat is offline   Reply With Quote
Old 05-19-2005, 06:25 PM   #2478
dougday's Avatar
Originally posted by joemugen
jefferlin,
did you notice that when you build your rear shocks to the size the manual says, it tells you to measure distance at bottom of alumuminum to the top of the plastic ball holder, that when you set your rear droop to 4 that when you attach the shocks it pulls the droop up???
Joe, you are probably measuring the droop from the wrong place. Look at the manual carefully , the droop is measured from a point below the arm and not from the bottom of the rear uprights as other manufacturers do.
dougday is offline   Reply With Quote
Old 05-19-2005, 06:28 PM   #2479
that is how i measured it.... how long did you make your shocks???
Joe Chaplow is offline   Reply With Quote
Old 05-19-2005, 06:57 PM   #2480
dougday's Avatar
I used the stock measurement and it worked fine. I was also using the upgraded rear shock tower. Not sure if that made a difference
Old 05-19-2005, 06:58 PM   #2481
i remeasured my shocks and some how they shortened up from when i built them.... i am thinking maybe from changing my ride height, the ball cup might of screwed in some!!!
Old 05-19-2005, 06:59 PM   #2482
doug,
you know where i can get a rrr world edition... me and danny are looking for one.
Old 05-19-2005, 07:10 PM   #2483
dougday's Avatar
I got the impression from Kyosho's website that they will start manufacture of them again in June.
Try Kyoshoamerica or RC-mushroom
Old 05-19-2005, 07:19 PM   #2484
thanks doug.
Old 05-19-2005, 07:45 PM   #2485
i know the kawhara disk brake is a good upgrade, but is there an upgrade for the brake pads... or do you use the stock brake pads with the kawahara disk brake?
Old 05-19-2005, 08:54 PM   #2486
AndyT 's Avatar
I`m pretty sure that Fast Tyres make an offset wheel (2mm that suits the MTX3)
Old 05-20-2005, 01:10 AM   #2487
jeffreylin's Avatar
R/C Tech Charter Subscriber
I use the stock brake pads with the Kawahara disc and it works great.
jeffreylin is offline   Reply With Quote
Old 05-20-2005, 06:49 AM   #2488
NiMo's Avatar
I found GQ 37's to work best on my track, but found it impossible to get them without 2mm offset.
NiMo is offline   Reply With Quote
Old 05-20-2005, 06:52 AM   #2489
jefferylin,
do you know where i can get the kawahara disc... i can not find it... also, where have you been??? (i have not seen many posts from you lately)
Old 05-20-2005, 09:01 AM   #2490
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Default Re: convert v-one rrr rubber tires to foam tires and wc
Originally posted by piorc
Hi guys, someone knows wich parts i need to buy to convert my rrr rubber tires edition to wc??
Please, if possible with part numbers.
Thanks a lot.
p.s: Some body has the setup used by Adrien Bertain at the worlds held in Brazil?
Thanks.
Marcelo
piorc: can you send me a copy of the basic set-up sheet of the rubber verion of the rrr??? i'm trying to convery my wce with foams to a rrr with rubber set-up and a front diff. thanks
doki_doki is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
