Old 05-19-2005, 12:27 AM   #2461
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: shopping for a new ride.....
Originally posted by ghoppa
jeffreylin
so you do "have to" use 2mm offset tires???? (such as "Fast Tires" for the MTX3)
I'm confused on your response....
with the shorter rear universals (VZW0007), what is the smallest track width you can run in the rear (190mm???)
"have you tried a spool in the front" @ Revelation????
You can use 2mm offset tires with the stock universal or use 2mm spacer between the wheel and the wheel hex. With VZW007, it's the stock setup for the non-WC edition and it uses 0 offset tires. As to how narrow you can make your rear track width I do not know as I never tried to run much less than 200mm. I use one way for Revelation and it works well.
jeffreylin is offline   Reply With Quote
Old 05-19-2005, 12:57 AM   #2462
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
ghoppa- The WC version comes with rear universals which require 2mm offset wheels. What you need to run 0 offset wheels in the rear are the VSW007. The name is a misnomer because the axle is actually 2mm longer. I thought about just widening the rear end and using 0 offset wheels but if you have too much droop the driveshaft can pop out of the drive cup.
Here are the universals you need to run 0 offset tires.
These are the universals that come with the kit.
Racing4Evo is offline   Reply With Quote
Old 05-19-2005, 02:35 AM   #2463
Trader Rating: 47 (100%+)
What are the part numbers for the WC rear uni's?
TOP GEAR R/C
EAST COAST HOBBIES
Craig1 is offline   Reply With Quote
Old 05-19-2005, 04:20 AM   #2464
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Default Re: Re: Re: TNX DOK!
Originally posted by doki_doki
i agree with you...just get the rest of the stuff except for the above mentioned vz204. this pack just contains the diff housing. as for me, i ordered everything that was listed in the manual. at least i have some spare parts lying around by the way, how's the handing of your rrr??? are you running oneway or regular front diff or a locked front diff???
RRR handling is great much much better than my RR evo still running with front one way will try to run front diffs next week i have not yet race this kit have to practise more
buboy28 is offline   Reply With Quote
Old 05-19-2005, 06:21 AM   #2465
bulletdays's Avatar
Default Buboy
You got PM
bulletdays is offline   Reply With Quote
Old 05-19-2005, 07:00 AM   #2466
ghoppa's Avatar
Trader Rating: 54 (98%+)
to make a long story short, the V One RRR WC uses a 2mm offset tire (just like the MTX3?????) (on all 4 corners)
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 05-19-2005, 07:15 AM   #2467
Airwide's Avatar
Send a message via ICQ to Airwide Send a message via MSN to Airwide
No, the RRR WC uses 2mm offset wheels in the rear and 0 offset wheels in the front.
Airwide is offline   Reply With Quote
Old 05-19-2005, 07:26 AM   #2468
does that mean you have to buy tires that have a 2mm offset as well?
Joe Chaplow is offline   Reply With Quote
Old 05-19-2005, 07:36 AM   #2469
kidDynomite's Avatar
Default Re: Oneway converted to solid??
Originally posted by bighurt98
Has anyone converted a oneway to a solid?
I have tried using the diff housing and 3 racing solid adaptor, but the diff housing hits the steering ackerman. Any fixes on diff??
Bighurt, I did one about a year and a half ago for my evo. It's still solid. Otherwise I would just go with heavy diff oil or gum.
kidDynomite is offline   Reply With Quote
Old 05-19-2005, 10:27 AM   #2470
ogreasurada's Avatar
Whats the difference of using a solid instead of a diff? or one-way?
ogreasurada is offline   Reply With Quote
Old 05-19-2005, 12:06 PM   #2471
jefferlin,
did you notice that when you build your rear shocks to the size the manual says, it tells you to measure distance at bottom of alumuminum to the top of the plastic ball holder, that when you set your rear droop to 4 that when you attach the shocks it pulls the droop up???
Old 05-19-2005, 12:19 PM   #2472
Airwide's Avatar
Just like jeffreylin wrote before: To use 0 mm offset tires on the WC, either put shims between the rear wheels and the hexes or get the VSW007 drive shafts.
/Arvid
Old 05-19-2005, 12:26 PM   #2473
/Arvid
thanks, completely forgot about that conversation!!! but i do remember now. i must not have been thinking when i wrote that reply.
Old 05-19-2005, 01:36 PM   #2474
robertr's Avatar
Default pulleys
I just wanted to know if there are any other pulleys for the rear side belt that can be used for a quick fix untill OEM part comes in? Also where can i get parts here in the US. for quick shipping. thanks for your help guys!
V one RRR/ JP Mod
robertr is offline   Reply With Quote
Old 05-19-2005, 03:00 PM   #2475
jeffreylin's Avatar
jefferlin,
Not mine but it's close. You can use longer ballcup or make your shock a bit longer if that bothers you.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
