Old 05-18-2005, 06:45 AM   #2446
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Default Re: TNX DOK!
Originally posted by bulletdays
If i am not mistaken this is the same in the Kyosho website right? i have some extra diff gears in my vone SII do you think i can use that... about the pulley set is there any extra pulley included in the WC kit or i really need to get this part.
Ive tried to put my VoneSII TCD and it works fine...
the extra diff gear in your s2 will work fine just get the other parts that doki listed but i think you wont be needing the vz204 since you already got the extra front diff gear case
buboy28 is offline   Reply With Quote
Old 05-18-2005, 07:19 AM   #2447
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Default Re: Re: TNX DOK!
i agree with you...just get the rest of the stuff except for the above mentioned vz204. this pack just contains the diff housing. as for me, i ordered everything that was listed in the manual. at least i have some spare parts lying around by the way, how's the handing of your rrr??? are you running oneway or regular front diff or a locked front diff???
doki_doki is offline   Reply With Quote
Old 05-18-2005, 08:27 AM   #2448
NiMo's Avatar
Default Re: Re: Thanks Guys
Originally posted by doki_doki
hmm...i seem to have difficulty finding the parts listed to convert the rrr wce to a regular front diff. anyways, i looked it up in my manual. here goes:
VZ218 differential joint (19)
VZ012 differential gear set
BS107 bevel shaft
VZ203 pulley set (rrr)
VZ204 differential pulley set (rrr)
hope this helps
Pulley set not needed in WC kit as 23T and 24T pulleys are in the kit.
NiMo is offline   Reply With Quote
Old 05-18-2005, 08:52 AM   #2449
Send a message via ICQ to piorc
Default convert v-one rrr rubber tires to foam tires and wc
Hi guys, someone knows wich parts i need to buy to convert my rrr rubber tires edition to wc??
Please, if possible with part numbers.
Thanks a lot.
p.s: Some body has the setup used by Adrien Bertain at the worlds held in Brazil?
Thanks.
Marcelo
piorc is offline   Reply With Quote
Old 05-18-2005, 12:49 PM   #2450
kewdawg's Avatar
Default Re: convert v-one rrr rubber tires to foam tires and wc
Thanks a lot.
Thanks.
Marcelo
The box set-up for the RRR World's Edition, IS the Adrien Bertain set-up - hence the name "WC Team Edition". It's not just a name, piorc. The REAL question is: how do you build the front rigid axle / solid spool? The plastic internals come in the kit, but what about the rest and some instructions?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 05-18-2005, 01:04 PM   #2451
kewdawg's Avatar
Default Re: Re: RRR wc
it is not a misprint
The manual is correct - the supplemental "WC TEAM EDITION SETTING DATA Ver 2.00" is a misprint for the rear toe angle. It should read: -2. You cannot run toe-out, in the rear, on a touring car. You would never make it around a corner. Rear toe-in keeps your tires from breaking free as you go AROUND a CORNER. Try it at your own risk.
Quinn Moon
Old 05-18-2005, 02:05 PM   #2452
kewdawg's Avatar
Default Re: Re: convert v-one rrr rubber tires to foam tires and wc
I read back a few pages and found the answers, thanks.
Quinn Moon
Old 05-18-2005, 02:08 PM   #2453
where do u find them?
Old 05-18-2005, 02:18 PM   #2454
kewdawg's Avatar
Thanks a lot.
Here you go: lightweight 1st Gear Housing (TSW15) / One-piece Engine Mount (TSW27) / Universal Swing Shaft (F:VZW054 / R:VSW015) / Upper Deck (VZ230B) / Rear Shock Stay (VZ231B) / Carbon F-shock Stay (VZW052) / Aluminum Brake Hub (VZW205) / FRP Battery Plate (VZW208) / FRP middle Plate (VZW212) / SP Drive Belt 189, 384, 180 (VZW201, 202, 203) / Shielded Bearing (BRG002, 022 for Linkage, Steering)
-Although, as previously stated, You'd probably, be better off buying the World's kit.
Quinn Moon
Old 05-18-2005, 02:20 PM   #2455
kewdawg's Avatar
Page 80. Although, still lacking actual written instructions from Kyosho.
Quinn Moon
Old 05-18-2005, 09:10 PM   #2456
bighurt98's Avatar
Default Oneway converted to solid??
Has anyone converted a oneway to a solid?
I have tried using the diff housing and 3 racing solid adaptor, but the diff housing hits the steering ackerman. Any fixes on diff??
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 05-18-2005, 11:49 PM   #2457
ghoppa's Avatar
Trader Rating: 54 (98%+)
Default shopping for a new ride.....
Hey guys just a couple of questions:
I am getting ready to do some gas racing again, and I was lookin into the "RRR-WC" version, but I was wondering if the car is "race ready" out of the box????
I previously owned a Prospec MTX3, but with the rumors of the "4" coming out, and no-one knowing a "true" answer to when it's coming out, I was looking to "jump" over to the Kyosho camp and trying something new.....
the WC version looks interesting, but I wanted to hear from the ones who already own one...
1. does it come with a one-way?
2. are there any nessesary upgrade/hop ups that you recommend me buying for strength/performance gains (not "bling/bling")
3. is the wheel/tire geometry "standard" offset, or are they like the MTX3 (2mm offset)
4. how is the "clutch"?? (solid like the Mugen?)
I don't want to right a "book" here, but I just want to hear the facts!!!!!
R1 Wurks - ActivRC - ApexRC - P1 Brands
ghoppa is offline   Reply With Quote
Old 05-19-2005, 12:02 AM   #2458
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: shopping for a new ride.....
yes.
yes
not for the WC. Perhaps the shorter rear universal VZW007 so you won't need to use 2mm offset tires.
front is 0 offset, see above for rear
Never had a problem with Kyosho clutch.
jeffreylin is offline   Reply With Quote
Old 05-19-2005, 12:07 AM   #2459
bulletdays's Avatar
Default Hi Ghoppa
The RRR WC Edition if i am not mistaken is the car who won the ifmar, and you will find a setup sheet which the team kyosho uses for that race, and i believe that once you assembled it and set it up on right track, its ready to go, and you dont need anymore hop ups or upgrade because its already upgraded and ready to go.
Sorry i dont have any idea of some other brand you listed in your message... I only have Kyosho.
You can ask other guys here and they'll tell you more.
Morespeed...
bulletdays is offline   Reply With Quote
Old 05-19-2005, 12:13 AM   #2460
ghoppa's Avatar
Default Re: Re: shopping for a new ride.....
Originally posted by jeffreylin
yes.
yes
jeffreylin
so you do "have to" use 2mm offset tires???? (such as "Fast Tires" for the MTX3)
I'm confused on your response....
with the shorter rear universals (VZW0007), what is the smallest track width you can run in the rear (190mm???)
"have you tried a spool in the front" @ Revelation????
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
