Old 10-15-2004, 08:53 AM   #226
Pyramid's Avatar
Originally posted by prawntoe
alot of the tanks leaked, including mine and alot of the guys I know.
only a few are ok.
strange . . kyosho quality is usually very good.
wonder if we will ever get a replacement tank
The fastest permanent fix you might be able to do is to find someone with plastic ultrasonic welding machine. Most likely you could find them on plastic manufacturer of car parts such as seat belt system (the cover is joined together) or plastic toys factory or even the machine sellers. Just make sure the area that is leak is not in special shape such as curve or something else as it will require special design molding.
Hope it helps..
Pyramid is offline   Reply With Quote
Old 10-15-2004, 08:54 AM   #227
Pyramid's Avatar
Originally posted by BrainTeased
[url]hey guys does this include the rear uprights as well? as the pic is to small i cant see...
thanks in advance
I really like your avatar
Old 10-15-2004, 08:58 AM   #228
Default Leak tank
Hi,
Just return your tank to Kyosho and you will receive a new one.
I had the KX-one TC and the belt did brake after two runs.
I returned it and did get a new one for free.
Bye Thomas
840918001 is offline   Reply With Quote
Old 10-15-2004, 11:14 AM   #229
prawntoe's Avatar
Hope it helps..
the fastest fix is bring it back and get it replaced. we paid good money and now we have to even learn what a plastic ultrasonic welding machine is ?
thanks pyramid, that's good advice
prawntoe is offline   Reply With Quote
Old 10-15-2004, 11:53 AM   #230
Data's Avatar
still need a horn/nest set to make it work correctly, also need to know the correct machine settings to get a good weld and the energy directors on the tank most likely are gone from the first weld, a second weld will not always work. too much trouble to fix one or two tank, i think. but then again, if someone can make a EDM hole in a couple of minutes, may be someone can do it without any trouble too. talk is always easier.
Data is offline   Reply With Quote
Old 10-15-2004, 02:09 PM   #231
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Someone posted a fix earlier but I will repeat it:
SOLDERING IRON
It works just as well as that fancy plastic welder. Fortunately I happened to get one of the good tanks. I'm still weary though so I'll periodically check for a leak until I'm satisfied.
Racing4Evo is offline   Reply With Quote
Old 10-15-2004, 11:03 PM   #232
Bundy_Bear's Avatar
Originally posted by NiMo
IC Scale Touring Rubber
IC Scale Touring Open
IC Circuit Open (200/235/8th)
Electric
27T/19T/Mod/F1
NiMo: What car are you running for the Rubber class at the moment? And what surface are you running on Asphalt or Concrete?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-16-2004, 02:15 AM   #233
NiMo's Avatar
BB
FW05R / Asphalt
NiMo is offline   Reply With Quote
Old 10-16-2004, 03:03 AM   #234
Bundy_Bear's Avatar
FW05R / Asphalt
NiMo:
Thanks...
Have you tried the V1RRR on rubbers yet? Having owned a FW-05R before i know the shocks are much more upright then the V1RRR...
BB
MissMooRC Racing
Old 10-16-2004, 03:24 AM   #235
NiMo's Avatar
NiMo:
Thanks...
BB
I don't have the RRR, but reading the worlds report I could well be getting one when cash flow allows, then the FW05 will be for Rubber and the RRR for Foam.
Old 10-16-2004, 03:36 AM   #236
markp27's Avatar
Send a message via ICQ to markp27
Michel at www.the-border.com is getting some in, so give him a shout if you'd like to order one, too.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 10-16-2004, 03:37 AM   #237
ziggy12345's Avatar
Join the (very large!) queue
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-16-2004, 03:45 AM   #238
NiMo's Avatar
Cheers, Mark.
Best deal at the moment works out at 198 + postage, I don't quite have that amount spare at present, then there's the servo's.
Old 10-16-2004, 08:02 PM   #239
kidDynomite's Avatar
here it is fellas:
IFMAR Worlds Brazil
1 Adrien Bertin V-one RRR
2 Takaaki Shimo V-one RRR
3 Chris Tosolini V-one RRR
+ the 3R filled in 8 of the 10 Final Spots.
Good job guys!
kidDynomite is offline   Reply With Quote
Old 10-16-2004, 08:16 PM   #240
Racing4Evo's Avatar
Did we think any other car was going to win it? Not. Still, this is very exciting for Kyosho fans.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
