Kyosho v-one rrr
#2221
ANOTHER
#2222
ONE MORE
#2223
LAST ONE
#2224
Re: Re: rrr
Originally posted by Dynamite
FDR:2
which drivetrains ones do you want to know, if its the ones that connect with the middle belt they are front 23 and rear 18 - with a 2mm split of tires, or swap the 23 for the 24 (requires and optional belt) and run all 4 tires the same size.
FDR:2
#2225
Suspended
WHAT ENGINE IS THAT? CHOCO
#2226
#2227
I am setting up my RRR to run outlaw.
Can somebody here advise me on body mounting for this configuration?
What front bumper to use? Front body mounts?
Any adjustments to the Rear body mounts?
#2228
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally posted by buboy28
IT'S A NOVAROSSI RR L5
#2229
rubber tires
does anyone have a rubber tire set-up sheet for the v-one rrr wce??? i want to compare my set-up with the set-up recommended by kyosho. thanks
#2230
Completed at race day ! with Kawahara Sway Bar , Kawahara brake and the adaptor. The rest - stock. Feel easy to drive and setting compare then my FW05RR. FW power accelerating but sensitive track surface - traction.
#2231
Originally posted by doki_doki
nice car pare... by the way, is that a mspeed modified novarosi engine??? how much did you get it for??? if got myself and rb v12 5 ports turbo tuned by rody engine. cost me P21,000. i was wondering how much you got your engine for...
#2232
gearing
dynamite,i need all pulley tooth count that a belt drives on including rear diff thks
#2233
yes it's a novarossi 12RR L5 tuned by m-speed cost me around P29,000 (58,000 Yen)
#2234
Re: gearing
23-18-^ Front Diff (27?)
18-21-^ Rear diff??
#2235
Re: Re: gearing
well i cant remember the front and rear diff teeth count, cant even find that in the manual they should be stamped on the gears if someone else has one apart or knows from the top of there head... what i can tell you tho...
18-21-^ Rear diff??
18-21-^ Rear diff??
Front
27T
24T 18T
18T 21T
42T
Rear
The 24T side pulley can be replaced with 23T if you want to run a split.
