Old 04-22-2005, 07:40 AM   #2206
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally posted by TRAJ
That cant be done the mount will hit the bearing block the only way is to buy the skyline part or use the existing mount
i also have i wce...the pipe holder included in the kit fits perfectly and does not hit any part of the bearing block...
doki_doki is offline   Reply With Quote
Old 04-22-2005, 07:44 AM   #2207
doki_doki's Avatar
Default Re: 9451 SERVO
Originally posted by buboy28
ANY OF YOU GUYS HAVE PROBLEM USING THIS SERVO AS STEERING FOR THE RRR MINE IS TOUCHING THE RECEIVER BATTS AND BARELY CLEARING THE SERVO BODY, ALREADY CUT OFF SOME OF THE SERVO HORN BUT STILL TOUCHING THE RECEIVER BATTS
never had problems when i installed my s9451 on the rrr wce. it fits perfectly. i used a team magic nylon servo horns... works great. no modification required except to cut the unused horns...
Old 04-22-2005, 01:33 PM   #2208
Default Sway Bars
QUESTION 1: I have heard that if you put the front sway bar horizontal instead of vertical makes it more hard. Is that true?
(By the way in simple RRR is vertical and in the WCR edition is horizontal)
QUESTION 2: In a bumpy techical slippery truck, what is better, a soft or a hard sway bar?
QUESTION 3. In RRR WCR the posts of the rear sway bar are adjustable in length. What does it do? What difference does it make if I change the legth of these posts?
REQUEST : I would like to see some more pics of your RRR's boys! Just send some pics!!
dmastroy is offline   Reply With Quote
Old 04-22-2005, 02:58 PM   #2209
doki_doki's Avatar
Default Re: Sway Bars
i think it's the other way around. putting the front sway bar in vertical makes it the hardest setting.
in my experience with bumpy tracks, i would go with the softest sway bar. sometimes, i even remove the sway bar unit to get the most shock travel out of the kit.
haven't really tried on exprerimenting on this aspect of the kit yet... will try is soonest when i get back to the tracks. i'll keep you posted.
Old 04-22-2005, 03:32 PM   #2210
Data's Avatar
i think it is used to make the left and right arm even when the sway bar is attached. kind of like the eccentric knob of the front sway bar.
data
Data is offline   Reply With Quote
Old 04-22-2005, 05:35 PM   #2211
Default guys whats the best kyosho has to offer??
in the fall 2004 issue of touring cars the fw-05r was rated the best chassis.
my question is which one is better, the fw-05r ,or the v one r or the v one rrr?
pls lemme know, i'd like to add a kyosho to my line-up!
farrk007 is offline   Reply With Quote
Old 04-24-2005, 04:13 AM   #2212
AndyT 's Avatar
The RRR wasnt released at the time of those reviews, hence no mention was made of it in the 2004 Touring Car Review.
Kyosho drivers for the 2004 World Championships were offered the choice of either the RRR or the FW05R with a majority of them opting for the RRR due to its better handling and higher top speed on this particular track.
Theyre both outstanding cars and whichever one you choose I`m sure you wont be disappointed....bear in mind the FW05R is shaft driven and the RRR is belt.
One feature that i find very pleasing about the belt driven RRR is the ease of access to the 2 speed transmission and also to the clutch bell/clutch area....its simply a case of undoing a couple of screws and you`re able to easily work on these sections of the car.
Cheers
AndyT  is offline   Reply With Quote
Old 04-24-2005, 04:17 AM   #2213
AndyT 's Avatar
Doki is correct.....vertical position makes the front sway bar harder, horizontal and its softer......vertical position will make the car understeer more/ create more rear traction.
Cheers
Old 04-24-2005, 09:40 AM   #2214
Default rrr
what is the internal gear ratio of the RRR ,also what are the pulley tooth counts on the drivetrain? thks
isuzuguy is offline   Reply With Quote
Old 04-24-2005, 12:00 PM   #2215
ziggy12345's Avatar
I was looking at getting a spare car. does anybody sell the non WC version?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 04-24-2005, 04:10 PM   #2216
performula's Avatar
Cheers
www.towerhobbies.com
performula is offline   Reply With Quote
Old 04-24-2005, 07:21 PM   #2217
Dynamite's Avatar
Send a message via MSN to Dynamite
Default Re: rrr
FDR:2
which drivetrains ones do you want to know, if its the ones that connect with the middle belt they are front 23 and rear 18 - with a 2mm split of tires, or swap the 23 for the 24 (requires and optional belt) and run all 4 tires the same size.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 04-24-2005, 08:30 PM   #2218
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Default RRR WC
MY RIDE
buboy28 is offline   Reply With Quote
Old 04-24-2005, 08:32 PM   #2219
buboy28's Avatar
ANOTHER ONE
Old 04-24-2005, 08:33 PM   #2220
buboy28's Avatar
AND ANOTHER
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
