Kyosho v-one rrr
#2146
also, anyone who has bought this in the past... could you please write here how you feel about it? (only if you liked it, just kidding)
#2148
That cant be done the mount will hit the bearing block the only way is to buy the skyline part or use the existing mount
#2150
Skyline Mount!!
The skyline mount is made for the standard kit and not the new top deck in the WC kit. The mount hole for the skyline mount is further back on the top deck behind the top deck mount hole. Unless you modify the top deck, the skyline mount can't be used on the WC kit Top deck!
#2151
Re: ???
Originally posted by bighurt98
I have the WC kit myself and the mount does fit under the top deck! Here is a picture!
Can you post a picture where I can see how your exhaust is fitted?
If I do what you did and try to put my exhaust on the same level with the tank then there will be a constant pressure in the manifold. I mean that if I dont install the mount of the exhaust, then it will "stand" just as you see it in my pic...
#2152
There are a number of ways to mount the pipe......
I`ve used the wire pipe mount off a NTC3. It simply goes through the vacant upper deck hole and is secured using a 3mm bolt, 2 3mm washers and a 3mm nylon nut.......havent had any probs at all with it.
I`ve seen another setup, where a guy made up a spring "loaded" type pipe mount, this actually allowed the pipe about 1 - 2" of inwards movement in the event of a side-on hit....he claims this helped reduce damage to his pipes from side-on hits.
Cheers
Cheers
#2153
i mounted my pipe exactly as per the instruction from the kit (from below of the upper deck), same as bighurt98. initially was afraid that if the car suffers a hit from the side, will push the wire mount to the pulley, but so far no problem at all
#2154
#2155
haha, i forgot to tell u all that it was only a few runs and one race.
so....
so what's the best way to mount it? from top?
so....
#2156
Re: ???
#2157
so....
so....
#2158
thanks! but too bad so far i never see any team magic mount here... will definitely find alternatives
#2159
Car body length
What car body length suits the RRR?
I find those 200mm body length a little tight....the wheel arcs dun really match...as in the rear wheels will be off by around 5mm.
#2160
9451 SERVO
ANY OF YOU GUYS HAVE PROBLEM USING THIS SERVO AS STEERING FOR THE RRR MINE IS TOUCHING THE RECEIVER BATTS AND BARELY CLEARING THE SERVO BODY, ALREADY CUT OFF SOME OF THE SERVO HORN BUT STILL TOUCHING THE RECEIVER BATTS
