Old 03-30-2005, 02:21 AM   #1936
Timox's Avatar
Oh, one last question.
Are there any parts on the WC edition even worth having to put on a normal rrr ? Things that will make it handel better and put in faster lap times is what i am after. Things that make it stronger do not concern me. hehe i dont crash... much
Timox is offline   Reply With Quote
Old 03-30-2005, 02:35 AM   #1937
jeffreylin's Avatar
R/C Tech Charter Subscriber
The one piece engine mount will make your chassis stiffer and dissipate heat better.
The side plate will move your belt tensioner toward the rear so your side belt won't touch the header.
The new upperdeck has a design that help prevent the tank air leak problem.
The universals could be more efficient than dogbones.
jeffreylin is offline   Reply With Quote
Old 03-30-2005, 02:53 AM   #1938
Send a message via ICQ to SpeedsterRRR
Hey Guys!!! Just started the assembly of a WC kit
Did any of you, who have the WC kit, use the front diff as a rigid axis?
Are the new ball ends provided with the WC kit lower enough to fit with the diff, or is there still the problem with the ballcaps hitting the diff case?
SpeedsterRRR is offline   Reply With Quote
Old 03-30-2005, 05:15 AM   #1939
Timox's Avatar
I thought the idea of a 3mm chassis was to flex a bit for bumpy track handeling.
Old 03-30-2005, 07:16 AM   #1940
jeffreylin's Avatar
I agree. But if you look at your car there is really only one plastic bar supporting the front and rear section of the car. If you remove (or if the screw comes loose) you can actually bend your chassis slightly. The engine mount helps that a bit.
Old 03-30-2005, 02:52 PM   #1941
hi,
i have installed the new radio tray on my car. are you suppose to put rubber groumets (spelling) inbetween the gas tank and radio tray on the front and rear screw? thanks in advance i did but it seems as though it makes the tank bind a bit... it is not as free.
Joe Chaplow is offline   Reply With Quote
Old 03-30-2005, 03:19 PM   #1942
markp27's Avatar
Send a message via ICQ to markp27
The once piece engine mount will make the chassis a bit stiffer, which is good for many circuits which are so bumpy - Brazil was a bit extreme. Also a big advantage of the one piece is that it reduces the stresses on the engine - with the two piece engine mounts, the engine twists a lot more - which isn't so good.
So it isn't just the one advantage, there are quite a few for the one piece.
markp27 is offline   Reply With Quote
Old 03-30-2005, 06:38 PM   #1943
jeffreylin's Avatar
Originally posted by joemugen
hi,
The fuel tank should install the same as the stock, which means you should place an o-ring (front and rear) between the upper deck and the tank. You should not tight the screws all the way but leave them a bit loose (but not too loose) so the tank can slide back forth if pushed.
Old 03-30-2005, 07:45 PM   #1944
thanks jefferylin!!!
Old 03-30-2005, 09:14 PM   #1945
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
No I have a regular one but it's been upgraded to full WC spec except the rear shock tower. I am also using the longer rear universal so I don't have to get tires with offset.
Do I have to run offset with the WC??
Walter Diaz
wad is offline   Reply With Quote
Old 03-30-2005, 09:25 PM   #1946
jeffreylin's Avatar
The rear universal in the WC edition is 2mm shorter thus you will need to run 2mm offset rear tires or put 2mm spacer outside the wheel hex to make it 200mm. However, this is not necessary a bad thing as it is yet another tuning option that allow you to narrow your rear quickly without touching the pivot ball screws and thus affecting rear toe.
You can also replace it with the regular universal if that's what you prefer.
Old 03-30-2005, 09:53 PM   #1947
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
what's the part number of that longer rear universal
buboy28 is offline   Reply With Quote
Old 03-30-2005, 10:01 PM   #1948
jeffreylin's Avatar
VSW007
Old 03-31-2005, 02:22 AM   #1949
buboy28's Avatar
VSW007
OK THANKS, SO THIS IS ALREADY A HOP-UP OPTION
Old 03-31-2005, 07:12 AM   #1950
jefferylin,
let me see if i understand correctly. the only difference with the two mm offset is that if you set your car up to 200mm with the 2mm offset, but for the main (for whatever reason) i want my car to be 196mm i just put on rim without an offset. also, even though it has a 2mm offset, running rims with no offset will work fine? (assuming you make your track width using the no offset tires)
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
