Old 03-27-2005, 07:19 PM   #1891
from my experience, the 24t pully has much more even tire wear. but the 23t pully is faster (do not know the specifics as to why, but i get faster lap times with teh 23t pully--- i did numerous tests in qualifiers and compared the two). i run a 2mm split with the 23t pully. if you do not, after 8-9 minutes of driving, you will have smaller rear tires than front tires. 2mm split i have found to be perfect with the 23t pully.
Joe Chaplow is offline   Reply With Quote
Old 03-27-2005, 09:22 PM   #1892
TexasRacer's Avatar
Send a message via AIM to TexasRacer
Awesome thanks Joe and Ron! I found a used car that Ken from skyline told me about and it is the car he used to take the pics for the skyline site. Ron I called you but you never returned my call you punk!
TexasRacer is offline   Reply With Quote
Old 03-27-2005, 10:02 PM   #1893
jeffreylin's Avatar
R/C Tech Charter Subscriber
i too run 2mm split. i also find that anything bigger than 57mm-59mm will adversely affect the handling of the car (well my car anyway). 55-57 works real good.
jeffreylin is offline   Reply With Quote
Old 03-28-2005, 07:10 AM   #1894
wow, you must run on a very very flat track with awesome (or very new) asphalt?
Old 03-28-2005, 09:11 AM   #1895
GUINT1's Avatar
Default 2MM SPLIT
HELLO GUYS
Buy running the RRR with so small diameter tires to start. With
a 2mm split. What is the ride height that you guys are starting
out with? what compound?
And i would like to know what's your tire wear is like?
GUINT1 is offline   Reply With Quote
Old 03-28-2005, 09:21 AM   #1896
Default Re: 2MM SPLIT
Originally posted by GUINT1
HELLO GUYS
everything that you asked is very dependent on the track you are running on. if you are running on a smooth track, very good asphault (newer and the grade is good, like tennis court grade), then you can run the car low. maybe 3.0 in front and 3.5 in rear height. there will be less tire wear so mabye 56 in front and 58 in rear tire size. if the track is this smooth and the aspault is this good, i would use 40 or maybe 42 shore tires. now if the asphault is not as good, maybe even a little dirty, you will get more tire wear. thus you have to run your tires bigger, maybe start them at 61 in rear and 59 in front. also, if the track has any bumby spots, or just is not completely smooth, you have to run your car higher. maybe 5 in front and 5.5mm in rear height. you would want to run 37 shore tire. also, remember, the worse the traction on the track, the greater the tire wear will be--- so this is a good thing to consider when choosing your tire size and ride height. and the smoothness of the track is another facter. i hope this helps.
Old 03-28-2005, 09:50 AM   #1897
GUINT1's Avatar
Default My Track
Hey Joe
My track here is smooth but bumpy. I use 35 shore all around.
with split and without split. Ride height front 6mm and rear 7mm.
When i use 37 shore or 40 shore my car slides to much.
Those are the shores that i would like to use but i just cant seem to get it right. So i stay with 35s
Also i get tons of traction on and off power. Ive tried diffrent springs/oils and shock positions. Whats my problem?
I drive very hard and deep as i can into the hole with my car.
But there is no way i can do that with 37 or 40s.
So you must know my tire wear is bad when it comes to a
30 or 45min main. Ive lost lots of races because of this.
Old 03-28-2005, 10:08 AM   #1898
jeffreylin's Avatar
Yea, revelation is pretty smooth. Being in LA the tracks does not take as much beating from the weather (except this year that is).
Old 03-28-2005, 10:10 AM   #1899
jeffreylin's Avatar
HELLO GUYS
The track here is smooth VHT prepared. We mostly run 42 front and rear and tire wear is minimum when traction is good.
Old 03-28-2005, 10:19 AM   #1900
Default Re: My Track
Hey Joe
have you tried using more tow in in the rear. i do not know what you use now, but maybe go to 4 degrees. maybe even lower your droop settings. for a high traction track i use higher droop settings. but for a lower traction track use lower settings. try running 5.5 in front and six in rear (for ride height), 2 degrees camber in front, 4 degrees camber in rear, 1 tow out in front, 4 tow in rear, and a light diff oil---- 10,000. do not use the 30,000 that comes with the kit. also, try 0 droop in front and 4 in rear. if you already using this, try -1 droop in front and 3 in rear. then use 37 shore tire. with a lower shore tire you get much better traction. but you compromise in speed. a harder tire will run faster. that's my 2 cents, i hope it helps.
Old 03-28-2005, 10:21 AM   #1901
Default Re: Re: 2MM SPLIT
your are very lucky to have such a nice track. i only wish i could use 42 at my local track. vht---- what is that?
Old 03-28-2005, 10:22 AM   #1902
GUINT1's Avatar
Default springs
jeff
what color springs and shock oil should i use
on this bumpy track to make 40 or 42 shores work
for me.
Old 03-28-2005, 10:30 AM   #1903
jeffreylin's Avatar
Default Re: springs
jeff
for me.
I can't say for sure. It's not just the track but driving style as well. Maybe the best answer is just try to be smooth and not push so hard. You'd be surprised that your lap time might decrease even though you feel that you are being slower.
I do run on a different track in Taiwan. Smooth flowing but no VHT. At this track, 37 and 40 seems to work best. But aside from the tires, my 2 car setup is pretty similar. I use the kit spring (black front gold rear) but I have less toe in in the rear (as little as 1 degree). Shock oil depends on traction. I would run thicker oil (up tp 800) when traction is good and as thin as 400 otherwise.
Old 03-28-2005, 10:31 AM   #1904
dougday's Avatar
Run softer springs
dougday is offline   Reply With Quote
Old 03-28-2005, 11:01 AM   #1905
GUINT1's Avatar
Default softer springs
Originally posted by dougday
Run softer springs
whouldnt the car roll more
Greg
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
