Old 03-11-2005, 03:55 AM   #1726
TRAJ's Avatar
Originally posted by uaerc
I dont know if its wrong or not but just wanted to chek if most of them had this problem or only 9451 servos.
cheers
ZiiZoo
It Happened to me i use the 9451 servo
The RRR kit actually comes with special spacers for that servo so it will have enough room to clear the deck.
Just shim the servo and you wont need to grind anything.
TRAJ is offline   Reply With Quote
Old 03-11-2005, 05:02 AM   #1727
uaerc's Avatar
Sorry for the pic quality it done with my cell cam. This is what my RRR looks like.. if you look closer you could see the difference on the right side which i sanded......
uaerc is offline   Reply With Quote
Old 03-11-2005, 05:16 AM   #1728
TRAJ's Avatar
Put more shims on the screwheads on the screws that hold the servo inplace maybe 3mm should give you enough clearance
Old 03-11-2005, 03:24 PM   #1729
AndyT 's Avatar
I`m using the S9451 for both servos, and as Traj said- if you shim the 9451 correctly, you wont need to sand the upper deck.
I used the thick rubber grommet that came with the 9451 and this also helped to add a little more clearance.
The 9451 uses part # 112 as a shim rather than part #111.
Cheers
AndyT  is offline   Reply With Quote
Old 03-12-2005, 05:43 AM   #1730
uaerc's Avatar
thanks for the tip guys.. I had already sanded now, so i guess i will run with this also put in a shim and see... but i feel that it might then touch the battery !! coz as of now its just mm away from the battery. Will post another pic close up !
Andy the part # 112 is in the RRR kit or comes with the servo ??
Cheers
ZiiZo
Old 03-12-2005, 09:12 AM   #1731
subman's Avatar
Default Spare parts box?
I bought a rrr and I am putting together an order for spare parts and was wondering if anyone could help in what I should buy. (As locally parts are non-existant for this car) I know to order spare belts and arms but what are the parts that you have found that I should also order a supply of?
Thanks in advance
subman is offline   Reply With Quote
Old 03-12-2005, 11:53 PM   #1732
AndyT 's Avatar
Definitely get some spare spur gears- these to me are a must have spares item.
Its also handy to have spare pinions as well....I generally pre-mount these on a spare clutch bell to facilitate a quicker change-over if need be on race day.
One spare I`m glad i had was an spare rear diff housing....a stone on race day mashed my rear diff teeth rather badly, so i was glad to have a 3-Racing aluminium as spare ...hopefully the teeth on this will be a little more rock "resistant".
Also get a spare pulley set.
Cheers
Old 03-12-2005, 11:58 PM   #1733
AndyT 's Avatar
Cheers
ZiiZo
Part # 112 is in the kit.....you`ll find it on the set of parts shown at the bottom of page 5 on the instruction manual.
Cheers
Old 03-13-2005, 06:00 AM   #1734
bulletdays's Avatar
Guys
Thanks for the engine tips, i will read some reviews of these engines.
Tnx
bulletdays is offline   Reply With Quote
Old 03-13-2005, 12:20 PM   #1735
rcmike's Avatar
Trader Rating: 40 (100%+)
Default Kit and parts
Hi,Where in the states can you get parts on-line at for the car? Thanks
rcmike is offline   Reply With Quote
Old 03-13-2005, 04:15 PM   #1736
Trader Rating: 13 (93%+)
Default serpent 710 delrin pivot ball cups for rrr ??
hi
I just wanted to know if the serpent 710 delrin pivot ball screw nuts fit the v one rrr hubs ?
thanks
John
mrgsr is online now   Reply With Quote
Old 03-13-2005, 05:15 PM   #1737
Trader Rating: 19 (100%+)
Default Re: Kit and parts
Ive ordered parts from japan-rc.com, although I would email them for availability rather than using their website for ordering. Their email address is [email protected]. Excellent service and fast shipping from those guys. Ive also ordered from Tower in the past. Seems their carrying less, and are out of stock on a lot of the RRR parts (I assume because Kyosho is dropping Great Planes as their distributor).
sjr456 is offline   Reply With Quote
Old 03-13-2005, 06:06 PM   #1738
rowveg36's Avatar
Trader Rating: 21 (100%+)
guys, will the front universal from v 1 r/rr or g4 fit the rrr? i'm talking about the k factory ones, has anybody tried it? will it fit perfect? thaks in advance for any info:
rowveg36 is offline   Reply With Quote
Old 03-13-2005, 06:50 PM   #1739
GUINT1's Avatar
Default K FACTORY UNIVERSAL
YES IVE USE THE K FACTORY UNIVERSAL BEFORE
AND I MUST SAY. THEY ARE VERY WEAK IN THE JOINT AREA.
ALSO IF YOU TAP THE BOARDS OR HIT SOMETHING THEY WILL BREAK VERY VERY EASELY. BUT THE BEST THING ABOUT THEM. ARE. THEY COST $20 BUCKS FROM MY HOBBY SHOP.
THE KYOSHO UNIV COST $40.-
GUINT1 is offline   Reply With Quote
Old 03-13-2005, 10:50 PM   #1740
bulletdays's Avatar
Default Mini World RC Model
Hi guys, just want to know if anyone of you has ordered something from Mini World, because i ordered last week and until now the status is still pending... its already paid thru world pay. and the shipping methong i chose is EMS... does anyone of you faced the same problem...
and if you have the number of RC Model... pls let me know.
thnks a lot guys...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
