Kyosho v-one rrr
Old 03-06-2005, 04:12 PM
  #1651
FW-05RR's Avatar
Originally posted by DaRollaRacer
Yes, they do have but they are so much more expensive than that of their Japanese counterpart. Is there another Japanese shop I can get the WC from?
Dave
I don't believe so I may be wrong though
FW-05RR is offline
Old 03-06-2005, 08:40 PM
  #1652
Racing4Evo's Avatar
www.rc-champ.co.jp They are $10 more than at Futaba.
Racing4Evo is offline
Old 03-06-2005, 08:42 PM
  #1653
DaRollaRacer is offline
Old 03-06-2005, 08:48 PM
  #1654
FW-05RR's Avatar
how do you navigate through their website to see their products
FW-05RR is offline
Old 03-06-2005, 09:20 PM
  #1655
216.239.39.104/translate_c?hl=en&u=http://www7.ocn.ne.jp/~rc-champ/frame-car.html&prev=/search%3Fq%3Dhttp://www.rc-champ.co.jp/%26hl%3Den%26lr%3D%26sa%3DG
paste it in your browser I hope it works.....
Isaac is offline
Old 03-06-2005, 09:48 PM
  #1656
FW-05RR's Avatar
thanks
FW-05RR is offline
Old 03-07-2005, 08:05 AM
  #1657
Default Grinder
U got PM
kpjr is offline
Old 03-07-2005, 12:11 PM
  #1658
jrabbito's Avatar
Default Offser
Hi Guys,
Whats the difference in offset with the WC edition RRR front and rear.
Thanks,
John
jrabbito is offline
Old 03-07-2005, 12:59 PM
  #1659
Racing4Evo's Avatar
The front is the same as the regular RRR meaning you use 0 deg. offset wheels. The rear on the other had requires 2 deg. offset wheels to make width. It's just the universals that are causing this. You can replace them with the normal ones that include a 2mm spacer, use 2 deg. offset wheels or insert a 2mm hexx spacer between the hex and wheel.
Old 03-07-2005, 01:09 PM
  #1660
jrabbito's Avatar
Racing4Evo,
Thanks for the reply. I am just having a hard time understanding something. You said to replace them with the normal ones that include a 2mm spacer. Maybe I am missing something here. The regular kit comes with CVD's and the WC edition comes with Universals.
I have the WC edition so what now what are the normal ones?
Thanks,
John
jrabbito is offline
Old 03-07-2005, 01:12 PM
  #1661
anybody have a problem with the pinion gears wearing out fast? do they make hardened gears?
Joe Chaplow is offline
  #1662
jeffreylin's Avatar
Originally posted by jrabbito
Racing4Evo,
Thanks,
John
VSW007 is what you need.
jeffreylin is offline
Old 03-07-2005, 01:14 PM
  #1663
jeffreylin's Avatar
They do wear out pretty quick. K factory has the hardened pinion that will work for 2nd gear but no one that I know makes the smaller ones for the first gear.
Old 03-07-2005, 01:19 PM
  #1664
Data's Avatar
going to make harden pinions too ? do you think S.S. will work or just hard anodize ?
Data is offline
Old 03-07-2005, 01:55 PM
  #1665
Default RRR
Ordered mine today will arrive tomorrow. Can't wait to get my hands on it. I'm gonna use it for drag racing, with Os .18 tz
kpjr is offline
