Old 10-11-2004, 11:33 PM   #151
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by wad
Hi jeff !!
By any chance, do you know what is the internal ratio of the car
What's up Walter! I am going to be back and will see you at the next race.
I think the RRR's internal is exactly 2. But the kit set up has overdrive of about 1%.
This might help:
jeffreylin is offline   Reply With Quote
Old 10-12-2004, 12:09 AM   #152
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
This might help:
Thanks a lot
Walter Diaz
wad is offline   Reply With Quote
Old 10-12-2004, 05:41 AM   #153
pramac's Avatar
BB, had bit of a play on the weekend with the RRR. With the stock setup it has a lot better turn in than the Evo, the rear would spin around in the corners off power (typical V1R) but keep in mind I was using my 5 port RB with 20% nitro running on Sorex 32's (and running on a concrete track for those who don't know). I changed to the red clutch shoe, a lighter rear sway bar and heavier front springs which did help, but what I need to do is get some Sorex 40's cause the 32's were overheating. With a little more tweaking it will run on the concrete with rubbers and do it better than the Evo did.
Gavin.
Bayside - http://www.wynnumrc.org.au
Kyosho V One RRR Evo
Novarossi Plus 12-3SCT
pramac is offline   Reply With Quote
Old 10-12-2004, 05:44 AM   #154
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Default Re: Re: Re: weight difference
Originally posted by ziggy12345
We have 3 guys running the 710 at the club and mostly they are underweight by 50g so 1625 could be correct in race trim
Cheers
i see so 1625 is the weight of the 710 will all the necessary equipment to race the kit...thanks bro...
doki_doki is offline   Reply With Quote
Old 10-12-2004, 05:46 AM   #155
doki_doki's Avatar
Default Re: Re: V One RRR - Rubber Version
Originally posted by NiMo
finally a rubber version of the kit is out would anyone know what's the difference between the sponge tire version kit aside from the tire itself???
Old 10-12-2004, 05:48 AM   #156
doki_doki's Avatar
Originally posted by rcosmax
I finally had a weekend without typhoons and rain. Had a chance to run the RRR and had a great race day. I wanted to share the results with you. The race day was a casual format with many races getting under way when enough people were ready to run. I won all but 1 race and at the end of the day was overall fastest aswell! I had never beaten the fast guys at that track before, and I beat them cleanly so i was very very happy! The 3r was running great! so happy with this car. just wanted to share.
that's good to hear bro.. what engine are you running??? also, what pipe are you using???
Old 10-12-2004, 05:55 AM   #157
I have been reading these last few pages and i was wondering if Nimo had any problems with his belts hitting the exhaust. Also just wondering on the durability of these cars. I know the FW05r is a beast, but sluggish on steering, just wondering how well this RRR held up and how many hop ups you "actually" need to make the car sturdy right off the bat.
Thanks so much,
Mike
budlightnmyhand is offline   Reply With Quote
Old 10-12-2004, 06:00 AM   #158
ziggy12345's Avatar
Thanks so much,
Mike
I never had any problems with steering. I fitted the RRR front hubs and the optional steering plate and it was fine. Very stable on long sweeping corners. Drag break helps a lot and dont run more than 2deg toe in
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-12-2004, 06:42 AM   #159
doki_doki's Avatar
Thanks so much,
Mike
bro...josh cyrul is running his v-one rrr box stock on the ifmar worlds in brazil... i guess the kit is very race worthy out of the box without any hop-up parts to add..
Old 10-12-2004, 08:11 AM   #160
NiMo's Avatar
Thanks so much,
Mike
I don't have the RRR, I run the FW05 with RRR hubs.
The 05 is spot on with Rubbers but has an annoying push with Foams, and as I may be running in both championships next year I'm considering the RRR for foam use, so I'm simply reading what others have to say.
NiMo is offline   Reply With Quote
Old 10-12-2004, 09:19 AM   #161
afm
afm's Avatar
Default Re: Re: Re: V One RRR - Rubber Version
Couple of pages back, somebody posted a picture of differences, which are:
Front differential instead of one-way
Different pinion gears
Different front side pulley
Different rear uprights
Different shock springs (softer)
Different clutch shoe and spring
Different rear shock tower
AFM
afm is offline   Reply With Quote
Old 10-12-2004, 09:47 AM   #162
Can you buy one of the kits that includes both parts for foam or rubber tires?
Thanks,
Mike
Old 10-12-2004, 11:29 AM   #163
ziggy12345's Avatar
NiMo on foams????? I thought you was always a rubber man (so to speak!) LOL...
Sponsored by:
Norfolk and Chance
Old 10-12-2004, 12:04 PM   #164
NiMo's Avatar
I'm behind the push for Foam Tourers in the UK, or to put it another way, Anti-Wedgies.
Foam Touring has taken over from Wedgies at AMCC and the lap times are only 1 lap slower.
Old 10-12-2004, 01:10 PM   #165
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The Rubber version has different rear axles. The uprights are the same.
Racing4Evo is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
