Old 03-04-2005, 03:12 PM   #1621
AndyT 's Avatar
Default Re: Re: Diff Oils
Originally posted by rcrossco_1
Im builing a WC kit just now, and race on a tight, med-low traction surface.
30,000 kit rear seems way to stiff to me, can u even turn that?!!!
Thanks in advance
Ross
I`m quite pleased with the 30000wt in the rear diff. Last weekends Sydneys nitro GP was run a track that sounds similar to the track you plan to race on (tight/low-med traction)and the 30000wt was fine.
Cheers
AndyT  is offline   Reply With Quote
Old 03-04-2005, 03:22 PM   #1622
AndyT 's Avatar
What would be the advantage of the solid front vs a diff ?
Thanks!
A solid will have the same acceleration out of a corner that a front one-way has, as power is being applied evenly to both wheels.
The diff may experience some "slipping"/uneven power distribution out of a corner and hence a front one-way or solid should accelerate faster.
The diff should however provide more turn-in steering than a solid when off-power (fine tune this using different weight diff oils).
The RRR`s drivetrain seems very durable, but a solid will place more strain on drivetrain components than either a diff or one-way.
Cheers
Old 03-04-2005, 03:54 PM   #1623
FW-05RR's Avatar
anybody have any pictures of their v one rrr they can post
FW-05RR is offline   Reply With Quote
Old 03-04-2005, 04:06 PM   #1624
Grinder's Avatar
Cheers
I like the solid in the car. The car still has enough steering to be very aggressive with the solid, but still very planted. Hard breaking seems to go through belts faster than the one way. I also notice with the solid that the brakes fade big time, I have to dial in more brake every few minutes. I noticed at Winternats that the one way was faster, the solid would not allow me to get through the S turns fast enough.I don't use it everywhere, but a front solid will always be in my toolbox for this car.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 03-04-2005, 04:15 PM   #1625
Grinder's Avatar
I have pictures, but they are too big to post, and I don't have a program to resize them. I can email them to you and you can resize them
Old 03-04-2005, 07:32 PM   #1626
FW-05RR's Avatar
sweet send em over to [email protected]
Old 03-04-2005, 07:43 PM   #1627
CRASH TOM's Avatar
Thumbs up
Thanks guys for helping me with my setup, the tail has settled down now and I knocked 1 second off my lap times but now the front wheels are hopping when I accelerate out of the corners. Does anybody have any suggestions on how I can fix it.
Tom
CRASH TOM is offline   Reply With Quote
Old 03-04-2005, 07:47 PM   #1628
Tom
worn out outdrive ?
SHTKS is offline   Reply With Quote
Old 03-04-2005, 11:38 PM   #1629
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I got my V-One RRR WC edition today and I noticed some more things that weren't mentioned earlier.
1) the car comes with 4 extra bearings, 2 for the servo saver and 2 for the throttle linkage arm.
2) Most importantly, the rear universals use the short axles which means that you have to use 2mm offset tires in the rear or switch over to different universals in the rear. That is about the only thing I'm dissapointed in.
The 37 shore tires on new wheels that come with the kit are awesome. They are my favorite design and the look pretty strong as well.
Racing4Evo is offline   Reply With Quote
Old 03-05-2005, 12:38 AM   #1630
FW-05RR's Avatar
you have any pics of it?
Old 03-05-2005, 10:19 AM   #1631
Default Final Drive Ratio
Sorry if this has been discussed,but, what is the feeling on drive ratio (side pully) and tire dia.
I usually don't like a very loose car (too old) so I tend to run bigger front tires to settle the car down when I run a car with the same ratio front and back. As the main goes on the rears tend to wear more so by mid race the balance is very good, this usually make the car a little pushy at the start but it is much better from mid race on, at least the way I drive.
Any thoughts?
Ted Flack is offline   Reply With Quote
Old 03-05-2005, 05:19 PM   #1632
rfy
Hi Grinder,
I experienced a lot of diff to left front bulkhead binding when I tried putting in a spool..does any part require some modification to fit?
Anyone's 2 cents will be appreciated!
rfy is offline   Reply With Quote
Old 03-05-2005, 05:27 PM   #1633
rfy
Ted Flack Sorry if this has been discussed,but, what is the feeling on drive ratio (side pully) and tire dia.
personally I prefer to run the 24T mid pulley and have a 1mm split..front wheel drive bias..good steering no push..pulls rear along very tame
Old 03-05-2005, 07:10 PM   #1634
Grinder's Avatar
Originally posted by rfy
Hi Grinder,
I made a one way a solid by drilling and bolting.
Old 03-05-2005, 10:16 PM   #1635
FW-05RR's Avatar
Thumbs up
Grinder's RRR
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
