Kyosho v-one rrr
#1576
Originally posted by Team-RTR
i have an excellent setup for a small-medium track with low-medium grip, here it is:
front:
ride height:5mm
camber: 1.5 degree
toe out: 1 degree
springs: silver
front rollbar: flat
shock oil: 50
oneway diff
droop:1mm
rear:
ride height: 5.5mm
camber: 3.5 degree
toe in: 3 degree
swaybar: black
springs: silver
shock oil:50
rear diff oil: 15,000wt kyosho
droop:3-4mm depending on the technicality of the track
body: mazda 6
tyres: GRP 37sh front and rear
this setup makes the car ULTRA nimble but still very stable into the corner, i also found that with this setup only run about 0.5-1mm of split between the tyres, the car isnt taily but has excellent turn in and has alot more of a responsive feel.
front:
ride height:5mm
camber: 1.5 degree
toe out: 1 degree
springs: silver
front rollbar: flat
shock oil: 50
oneway diff
droop:1mm
rear:
ride height: 5.5mm
camber: 3.5 degree
toe in: 3 degree
swaybar: black
springs: silver
shock oil:50
body: mazda 6
Front ride height- 5.5mm
Front camber- -2 deg
Front toe- out 1deg
Roll bar- flat
Front one-way used
Front droop- 0
Springs- Black
Rear- toe-in- 3deg
Rear camber- -3deg
Rear droop- 4mm
Rear diff oil- stock 30000wt
Shock oil- 500wt all round
Body: Mazda 6 Protoform
Power tyres- 35 shore
An interesting point was quite a few drivers went to running front diffs......Ric apparently ran a front diff, but I`m not sure whether or not he changed back to one-way for the final?......i know Ron changed to a diff in his RRR for the last heat and said he regretted it....I`m not sure if he had time to change back to a one-way for his final....which he won.
Cheers
#1577
RRR
There are 2 versions of the car. The W/C or Team has all of the option parts on it. Kyosho only made 1 batch of these cars.
#1578
Originally posted by kt racing
Does anyone know when the RRR is going to be released in the U.S.?
thanks
thanks
#1579
thanks
thanks
www.elitehobbyshop.com
#1580
Originally posted by AndyT ©
My setup was relatively similar--
Front toe- out 1deg
Roll bar- flat
Front one-way used
Front droop- 0
Springs- Black
Rear- toe-in- 3deg
Rear camber- -3deg
Rear droop- 4mm
Cheers
Front toe- out 1deg
Roll bar- flat
Front one-way used
Front droop- 0
Springs- Black
Rear- toe-in- 3deg
Rear camber- -3deg
Rear droop- 4mm
Cheers
#1581
The brakes wouldve been a very nice bonus indeed...... i was tempted at one stage to go with a front diff, but my heat times kept coming down with a few subtle changes here and there, so i opted to continue with the one-way.
#1582
Does the car come with a one way or a diff?
#1583
#1585
Hi guys,
I was wondering what would be the of effect putting the 24T mid pulley and running even diameter tires as against the 23T pullley and a 2mm diameter split between the front and rear tires..thanks.
#1586
I haven't tried it personally cause I lost my 24t pulley but I have been told it takes out the aggressive nature of the steering when running equal diameter tires front and rear. I will be running it though on my other car when I build it. The split from running the 23t pulley just complicates the handling.
The car handles great with the 2mm split and 23t pulley but it can be a handful to drive depending on traction as the split wears away.
#1587
Some new parts.
#1589
Originally posted by subman
I just bought a RRR and parts availability is somewhat questionable
so I was wondering what I should stock up on and if anyone knows a good place to order parts from Thanks.
#1590
Originally posted by SERPENTFREAK69
FOR 2 DAYS,I HAVE BEEN TRYING TO CONTACT SERPENT VIA EMAIL....I DO NOT KNOW WHATS GOING ON..... CHOCO
Hes the same guy that tried to rip off 2 guys on another forum topic, I think on these same boards.
He basically kept there money on a false sale and then has the sheer cheek to ask if he could pay it back in installments to the guy he had ripped off.
No one can stand the guy, and to be honest he seems like he's utterly retarded with some of his posting.
So if hes offering to sell his serpent kit saying that the RRR is so good and he wants one then STAY AWAY!!!!!
Got My VoneRRR WC edition coming tomorrow! any tips at all?!
ta
