Old 02-22-2005, 06:43 PM   #1531
dameetz's Avatar
Default Re: ROLL CENTER CLIPS
Originally posted by jwf_frani
A: set on the lowest postition in the rear will lower your roll center.
B: set on the lowest postition in the rear is the next step up
B: on the reversed position would be next higher
A: on the high postion for the rear would be the highest setting.
(front)
the higher the inner hinge pin is the lower the roll center
How about the spacer on top of rear upright? If I add the spacer will it make the rear roll center lower?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-22-2005, 07:18 PM   #1532
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Default Re: Re: ROLL CENTER CLIPS
Right.
Racing4Evo is offline   Reply With Quote
Old 02-22-2005, 10:22 PM   #1533
bulletdays's Avatar
Default RC MOdel HK
Hi guys hows the RC Model right HK now, are they operational or still on vacation? i want to know coz i need to order some tires... tnx.
bulletdays is offline   Reply With Quote
Old 02-23-2005, 06:12 PM   #1534
Default v one rrr wc
Does that kit come with the kyosho foams (rim pattern) shown in the press release or regular grp 35 degree foams? Thanks.
1FastVW is offline   Reply With Quote
Old 02-23-2005, 11:23 PM   #1535
Dynamite's Avatar
Send a message via MSN to Dynamite
grp37's 26mm front 30mm rear comes with wc, they are spoked rims, but not the same as the regular type spoked ones
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 02-24-2005, 07:25 AM   #1536
rowveg36's Avatar
Trader Rating: 21 (100%+)
has anybody here using a team magic alpha starter box? will it work w/ the v one rrr?
rowveg36 is offline   Reply With Quote
Old 02-24-2005, 11:02 AM   #1537
Default rrr wc aditional parts
I am in the process of buying the WC edition. Without having to go through the whole thread, can anyone suggest what upgrades I should still get? I am ordering spare belts, and front suspension arms off hand. I am placing the order oversees, so I would like to make 1 big order.
Thanks in advance.
CHUCKMANDO is offline   Reply With Quote
Old 02-24-2005, 11:19 AM   #1538
bighurt98's Avatar
Default Option parts for RRR!!!!
Here are a few option parts to add!
1. Aluminum front sway bar
2. Aluminum center deck brace (2 pieces)
3. skyline 4mm rear shock tower
4. extra 55T and 56T spur gears
5. extra 16T and 17T pinions; get 1 15T pinion
6. front knuckles
7. pulley set
8. joint 19 outdrives
9. white shock diaphrams
10. rear uprights
11. small shock parts
12. extra front and rear bulkheads
13. skyline pipe support
14. aluminum center main shaft pulley for rear diff
15. front oneway and rear diff aluminum access covers
16. rear set diff gears
17. all sets of springs to go all around
18. Extra fuel tanks
19. replacement bearings
20. extra clutch bells for other gears
21. Venom 1200 maH battery packs (2).
22. extra pillow balls to replace a bent one
Hope this helps.
I went whacky on you!
Capricorn C03/Matrix Tires/Novarossi
Capricorn RC USA/RC Target
Murnan Modified Motors
Desoto Racing
Team Gravity
bighurt98 is offline   Reply With Quote
Old 02-24-2005, 03:49 PM   #1539
AndyT 's Avatar
You could also try one of the 3-racing lightweight clutch bells....by my calculations they weigh about 20% less than the stock Kyosho bell so it`ll be interesting to see what affect they have on performance........I havent had the chance to try mine out yet
Cheers
AndyT  is offline   Reply With Quote
Old 02-24-2005, 06:25 PM   #1540
Default Re: Option parts for RRR!!!!
2. Aluminum center deck brace (2 pieces) cou
6. front knuckles-- ARE THERE DIFFERENT ONES? -1, -2
7. pulley set
8. joint 19 outdrives --WHAT ARE THESE
9. white shock diaphrams fOR THE SHOCKS? mAYBE I CAN HOLD OFF ON THESE
10. rear uprights COULDN'T FIND PART NUMBERS
11. small shock parts WILL HOLD FOR NOW
15. front oneway and rear diff aluminum access covers-- PLEASE EXPLAIN THE ADVANTAGE, COULDN'T FIND THEM EITHER
19. replacement bearings IS THE ONLY PLACE WHERE THE CAR USED BUSHINGS IN THE KNUCKLES?
21. Venom 1200 maH battery packs (2). dOES THE CAR USE THE STANDARD FLAT PACKS
Hope this helps.
[COLOR=blue]WHAT ARE T
Thanks for the reply. I made some comments in Caps.. I appreciate the help. My ntc3 is so much easier to deal with
Old 02-24-2005, 09:25 PM   #1541
jeffreylin's Avatar
R/C Tech Charter Subscriber
Cheers
Kyosho came out with the RRR light weight clutch bell last month VZW213
jeffreylin is offline   Reply With Quote
Old 02-24-2005, 10:22 PM   #1542
Dynamite's Avatar
i have the x5 starter and no problems
Old 02-25-2005, 03:37 AM   #1543
Ec1
Ec1's Avatar
I`m going to svitch from a MTX-3 to a V1rrr.
Is there anything i should keep from my Mugen.... i have a ton of new spares from it, pinions cluchbells etc.... but i dont know if there is anything that fits the v1rrr
Ec1 is offline   Reply With Quote
Old 02-25-2005, 05:38 AM   #1544
Ec1
Ec1's Avatar
what i am realy intrested in is if the pinions, clutch bell work.... also is the Kawahara aluminium servoaver (ackerman) for the Mtx-3 a direct fit for the V1rrr....
Old 02-25-2005, 05:55 AM   #1545
InitialD's Avatar
Roland, why the switch? I thought you did very good with the MTX-3...
Why not get the RRR, build it and test it first before making the complete swtich? Then you'll know if you like it or not and if those Mugen parts you're asking fits on the RRR... Sure and safe way of knowing.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
