Old 02-18-2005, 02:57 AM   #1501
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by FW05R
Jeff are you coming to socal this saturday?
nope still in asia.
jeffreylin is offline   Reply With Quote
Old 02-18-2005, 06:08 AM   #1502
Default I need help/advice
Got the rrr kit, fixing it and i am facing problems now.
It's the direction for the throttle servo connecting to the brake & engine arm. Example, when i hold on to throttle on the tx the direction of the servo turns towards the front which is engaging the brake and closing the air-in-take for the engine.
I am using M8 tx/rx and my servo is sanwa(airtronnics) rs-991.
I have checked with pictures posted by Prawntoe and my direction and placement of the servo is exactly as in the pics.
Any comments, help or advice will be appreciated.
ahleon is offline   Reply With Quote
Old 02-18-2005, 06:14 AM   #1503
TRAJ's Avatar
You have your servo on reverse
Scroll through your M8 menu and find servo direction and put your throttle servo to normal and it should work fine.
TRAJ is offline   Reply With Quote
Old 02-18-2005, 08:08 AM   #1504
NiMo's Avatar
Originally posted by Racing4Evo
The PT is mounted in the stock location: the plactic mount above the steering servo.
I am going to buy the anti-electrical tape from Yokomo. They call it a "noise killer set. Whatever. I'm also going to stop by Airtronics next week and have them look at my radio because the blue LED broke. Looks like the gods are telling me to go back to KO.
Try moving it to the front bumper mount area, also check you do have it plugged in the right way round
(I have seen it plugged the other way and the interferance is not pretty)
NiMo is offline   Reply With Quote
Old 02-18-2005, 11:10 AM   #1505
ttso's Avatar
Default RRR with 710 ball diff, is that possible?
I don't know if it's possible, that's why I asked...
Both of them using 12x18mm bearing, width from bearing to bearing unknow (I don't have both of them to measure). Total width from cup to cup unknow, but RRR seems wider.
RRR rear gear ratio 42/21
710 rear gear ratio 45/24
By changing pully and tire diameter it should get a similar gear ratio. So the problem is on width. One with narrower bearing to bearing width should able to seat in other's bulkhead with some 12x18 shims. And if cup to cup is wide enough it should be function correctly (unless the CVD ballhead size is very different).
So.. is that possible to let RRR has a ball diff? or let 710 has a gear diff?
ttso is offline   Reply With Quote
Old 02-18-2005, 09:56 PM   #1506
phil's Avatar
Post Setup help
Does anyone have a setup sheet for a tight, low traction track?
phil is offline   Reply With Quote
Old 02-18-2005, 11:32 PM   #1507
Dynamite's Avatar
Send a message via MSN to Dynamite
Does anyone have a copy of the new version2 setup sheet in english, or know where i can download one from? the one that came with the wc is in japanese and i didn't pay that much attention to japanese class at school
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 02-19-2005, 10:21 PM   #1508
bulletdays's Avatar
Default Need your opinion
Hi to all,
When i start my engine, it idles perfectly normal, but after 2-3 laps the idle goes high and never comes back to normal idle.
wonder if its rich or lean?
which needle should i adjust the 'low speed or Main'
please advise... thanks in advance..
bulletdays is offline   Reply With Quote
Old 02-20-2005, 02:15 AM   #1509
Team-RTR's Avatar
your tank is leaking. you need to either:
1)run a soldering iron around the seam of the tank to sort of "re-seal" it, also buying the revised topdeck which stops tank leaks would help
or
2) buy a new tank and the revised topdeck
also after reading the review of the IFMAR 200mm NT worlds in RCCA, i was interested to find that in the A main the pressure line came of both david spashett and josh cyruls car. i have also encountered this problem, with the pressure line coming off for no apparent reason at all. how many people have also experienced this problem??
thnx
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 02-20-2005, 02:39 AM   #1510
jeffreylin's Avatar
thnx
Really? This is the first time I've heard of this problem.
Old 02-20-2005, 02:44 AM   #1511
Trader Rating: 47 (100%+)
Default Re: Need your opinion
Originally posted by bulletdays
Hi to all,
I'd bet that the lid of the tank leaks.
Put the tanks under water and give it a pressure test, you'll soon know.
TOP GEAR R/C
EAST COAST HOBBIES
Craig1 is offline   Reply With Quote
Old 02-20-2005, 02:52 AM   #1512
bulletdays's Avatar
Default tnx guys
The performance is ok, its just that the idle becomes higher after 3-5 laps of running.
Ok il try to see if theres a leak in my tank.
but do you think the tuning is ok?
Old 02-20-2005, 03:12 AM   #1513
If your happy that the tune seems ok once it's up to temp (hard to tell for sure if your not there) but after only a few laps of the warm up it just runs on and nothing you do seems to help, I'd guarantee you it's the tank lid.
My car would do exactly the same thing.
I ran it today with some seals that I made myself and it tuned perfectly and didn't run on once all day.
I haven't come up with a good use yet for the standard seal, but I'm sure someday it maybe useful for something because it sure doesn't work in the tank lid :-)
TOP GEAR R/C
EAST COAST HOBBIES
Old 02-20-2005, 03:15 AM   #1514
markp27's Avatar
Send a message via ICQ to markp27
Default Re: tnx guys
If your tank is ok - I would say that your lower needle is too lean.
If you're ever unsure, richen it - too lean can damage an engine, so it is always best to start out with it being too rich.
Also make sure that your idle isn't set too high.
A method I use to check the lower needle is a so called "pinch" method. Make sure you've put in a few good hard laps to get everything warmed up (chassis included) then bring your car into the pits - pinch the fuel tubing to where it enters the carb. If the engine dies straight away, then the lower end mixture is too lean. If the revs rise, this means the mixture is rich.
Ideally when you pinch the tubing, the engine revs should rise for about a second and then die off.
This is still just a "ball-park" method and will get you closer to the best setting. Best of all get someone from your track who knows how to tune a motor to set it up for you.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 02-20-2005, 03:53 AM   #1515
bulletdays's Avatar
Default tnx a lot
Craig - tnx, il check the tank out, and see if there's leak.
mark - tnx, i read about that pinch test. let me try richening the low end also.
tnx a lot
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
