Old 04-22-2011, 09:43 PM   #1
Jay7's Avatar
Send a message via AIM to Jay7
Questions?? Mugen Pro Starter II w/4s Lipo Help
Anyone have a Mugen Pro Starter II box and installed a 4s lipo? Looking for the correct diagram to install the lipo. Since the box has 2 tamiya connectors for the two nimh batteries. Any help would be greatly appreciated...
Jay7...
Jay7 is offline   Reply With Quote
Old 04-23-2011, 01:51 AM   #2
csterikim's Avatar
Jay7...
Mugen Pro Starter II w/4s Lipo Help-img_0183.jpg
Mugen Pro Starter II w/4s Lipo Help-img_0186.jpg
Dear
I installed 2 lipos in off road and on road Mugen starter boxes.
You should check the room of starter box for installing a new lipo battery.
I attacted 2 pics for you.
One is a off road and another is a on road.
I bought 2 lipos from Hobby King.
On road's room is smaller than off road starter box.
So I installed a 3300mh lipo for on road.
I put a 5000mh lipo in off road starter box.
Lipo size is depended on its capacity.
My friend installed a pro teck lipo which is a small size but its capacty is around 1650mh but it is so good for starter box and reduces the weight of starter box.
I am lazy so I need bigger.
It is easy but be careful. You only use iron and solding..
Connector is simple and you only check + , - .
Mugen MRX4X, JR Z9100t Servos, Nexus HV Servos, Life 6.6V, Futaba 4PK,
,Serpent 966 TE, Associated B4.1, Mugen MBX6 M-Spec, Yocomo YRX-12WE.
csterikim is offline   Reply With Quote
Old 04-23-2011, 09:58 AM   #3
CanyonCarverR1's Avatar
Jay7...
You can seperate the two 2S batteries in your 4S pack and put Tamiya plugs on them.
CanyonCarverR1 is offline   Reply With Quote
Old 04-23-2011, 10:10 AM   #4
wingracer's Avatar
Trader Rating: 24 (100%+)
Bat + to motor 1 + . Jumper from motor 1 - to motor 2 +
Bat - to switch. Other side of switch to motor 2 -
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-26-2011, 08:31 AM   #5
Jay7's Avatar
Thanx for the help...
Old 04-26-2011, 08:59 AM   #6
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Thats very dangerous, and I would never recommend opening up Lipos...
Its so easy to cut the cables from the switch and the motor which in turn removes the "jumper" between the tamiya plugs. And just solder a deans plug with those two cables (switch/motor)
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-26-2011, 10:38 AM   #7
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Yeap and solder the negative wires to the copper contact strips. Find a couple of o-rings to go around the contacts to apply tension when it is assembled.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
