Old 04-22-2011, 12:37 PM   #1
Unhappy picco carb
i have an older picco 21 i think they were sold by serpent. i got it with a 950. i put it in a new 966. can't get consistent idle , hard too start and no bottom end response. rough start too my 1/8th campain. i have already cleaned out the carb no change.
5italkart is offline   Reply With Quote
Old 04-22-2011, 02:47 PM   #2
Send a message via Yahoo to motojon
try a new glow plug
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 04-22-2011, 04:26 PM   #3
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Depending on how old it is, the carb could need new seals.
Wanabrc is offline   Reply With Quote
Old 04-26-2011, 12:04 PM   #4
Speyederjedi's Avatar
5italkart,
If you're having trouble with an inconsistent idle and not much bottom end response you may have a motor that has lost its pinch. You may want to replace the piston, sleeve and con rod or just purchase another motor. Once you have a motor with idle problems and you know the carb and o-rings and seals are all good then more than likely it's time to rebuild. Once the pinch goes away this tends to happen.
Regards,
Speyederjedi
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
LEAKING JPX JAMMIN / PICCO CARB TopGearRC Nitro Off-Road 11 07-31-2009 01:54 PM
