Old 04-18-2011, 07:39 PM   #1
Default New Kyosho inferno gt2, please help
Very new to R/C. Have a brand new inferno gt2. Having difficulty getting it started. I can get it to start after messing with the idle needle, the high speed needle, and the low speed needle. Also blowing into the exhaust seems to help. When I do get it to start, the wheels are turning super fast, and I basically have to hold the brake so it doesn't drive away. Need to know what should I do? Do I need to tweak the needles? Thanks for you help.
Nikosigs is offline   Reply With Quote
Old 04-18-2011, 08:42 PM   #2
gashuffer's Avatar
Trader Rating: 48 (100%+)
Your idle is too high. You need to set your carb up as per the instructions tell you. I would go back to factory needle settings.
What do you mean by blowing into the exhaust?
T-Sal
gashuffer is offline   Reply With Quote
Old 04-20-2011, 12:16 AM   #3
Trader Rating: 57 (98%+)
Default Inferno GT2
Yes, it sounds like your idle is too high. If your idle is ok try checking your clutch spring. Maybe your clutch spring snapped.
INFERNOZ GTZ is offline   Reply With Quote
