Old 09-13-2004, 04:00 PM   #1
mo
mo's Avatar
Default NTC3 Clutch Springs
Does anyone make clutch springs for the NTC3 that are harder than the copper stiff springs AE makes? The Schumacher R12 uses the same springs and shoes and I would like to find something a little stiffer. Thanks!
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 09-13-2004, 04:09 PM   #2
I may be wrong, but I thought that if you lightened the clutch shoes that it would have the same effect as a stiffer spring. I use the copper springs and lightened the clutch shoes to delay the timing of the engagement. I left the same amount of surface contact, but just removed alot of material from the center of the shoes.
sook is offline   Reply With Quote
Old 09-13-2004, 04:14 PM   #3
mo
mo's Avatar
Do you have a picture or can you describe where you took off the material? Did you just drill some holes through the top of the shoe?
Old 09-22-2004, 08:56 PM   #4
factory racer's Avatar
do u have any pics of how u did that to the clutch shoes???????????????
factory racer is offline   Reply With Quote
Mugen 1.1 clutch springs Greg C R/C Items: For Sale/Trade 7 09-06-2008 07:10 PM
Springs and Clutch Shoes Captpete Rookie Zone 0 03-07-2008 06:43 PM
MRX-3 clutch springs? JInaba Oval, Larger Scales and More 1 03-17-2005 02:09 PM
MRX-3 clutch springs? JInaba Nitro On-Road 1 03-17-2005 01:15 PM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
