Old 09-12-2004, 08:23 PM   #1
ntc3freak's Avatar
Wink stripped screw
one of my engine mounting screws is stripped.what should i do?i am looking to replace the stock rtr engine and pipe with novarossi nsr5 and rdlogics turbo pipe.is that a good choice?but first i need to replace the enhine mounting screw.what can i do?pleaz help me!
ntc3freak is offline   Reply With Quote
Old 09-12-2004, 08:51 PM   #2
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
While you are at it, look into putting on a k factory or kawahara centax clutch. it will help a lot getting all that new power to the ground. if you are racing just get the ns3 since 5 port motors are not legal anyways.btw, rd logics pipes rock.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 09-12-2004, 09:01 PM   #3
ntc3freak's Avatar
but that does not solve my main problem.how to remove the stripped screw?and how much is the centax clutch?
Old 09-12-2004, 09:08 PM   #4
sweetpea's Avatar
Dremel and a cutoff wheel........slot it so you can use a flat blade screw driver.......careful not to cut the chassis
sweetpea is offline   Reply With Quote
Old 09-13-2004, 05:44 AM   #5
ntc3freak's Avatar
thanx.is dremel good?is it high quality?
Old 09-13-2004, 01:28 PM   #6
calstarjig90j's Avatar
Any Dremel type tool will work. Sears and Black & Decker also make similar style tools. Anyways. Just make sure that after you slot it that you use a screwdriver tip that fits snug into the slot you made or else the problem will just get worse and you won't have anyting to slot anymore. If you use too small a screwdriver tip to remove you might end up widening the slot and you wont have enough grip to take out the already stuck screw. Also you want to make sure that when you turn your screw driver that you push in with enough pressure so that it doesn't slip out and destroy the slot you made. Just a thought because I know what your feeling. I've had to remove a couple of them darn things myself.
calstarjig90j is offline   Reply With Quote
Old 09-13-2004, 07:54 PM   #7
ntc3freak's Avatar
thanx.hope those tips helpful.just ordered my dremel.is it hard to remove coz there is thread lock on the screws?
Old 09-13-2004, 10:49 PM   #8
DerekB's Avatar
You can also drill out the head enough so it breaks off. If the chassis isn't threaded you can remove the other screws and then use plyers to get the rest of the screw out.
Velocity RC Magazine
www.vrcmag.com
DerekB is offline   Reply With Quote
Old 09-14-2004, 05:56 AM   #9
ntc3freak's Avatar
what is threaded chassis?u mean cutting the screw on the center line?
Old 09-14-2004, 08:22 PM   #10
JustRace's Avatar
Default Home Depot
Go to Home Depot and get a screw extractor. Get the smallest one that they have. It comes with a drill bit and the extractor. All you do is drill into the screw head. Tap the screw extractor into the head and remove screw. The extractor is reverse thread so when you turn to the left it's actually biting into the screw.
JustRace is offline   Reply With Quote
Old 09-14-2004, 08:33 PM   #11
ntc3freak's Avatar
but can it be fitted to a dremel?and i don't think i have saw it here in Malaysia.
Old 09-15-2004, 06:51 AM   #12
JustRace's Avatar
All you need is a drill. Just drill into the screw head and insert the screw extractor. Then use a pliers to turn the extractor counter clockwise. This will tighten the extractor into the screw because it's reverse thread.
I don't know what hardware store you have in Malaysia but I'm sure you should be able to find it.
go to www.homedepot.com and search for screw extractor
Old 09-15-2004, 05:12 PM   #13
ntc3freak's Avatar
is it the Hanson 5 piece Flute Screw Extractor Kit?
Old 09-15-2004, 08:16 PM   #14
JustRace's Avatar
Yes or any brand extractor will do. Just get one for the size of the screw you're trying to get out.
Old 09-16-2004, 11:43 AM   #15
Rapid Roy's Avatar
If its only one of the screws, you can remove the other 3, then rotate the engine while you use a screwdriver to hold the stripped screw. You won't need much force to hold the screw since you are turning the other end. I have done this many times. Works great.
Rapid Roy is offline   Reply With Quote
Urgent stripped screw help coons88 Electric On-Road 14 02-24-2007 04:46 AM
stripped pinion screw AZNracerx1989 Rookie Zone 3 08-02-2005 11:31 PM
Stripped Screw DIMO Electric On-Road 11 06-07-2005 03:57 PM
Stripped Screw RCDoon Electric On-Road 1 04-01-2003 09:11 AM
Stripped Screw Removal... skibum989 Electric On-Road 23 03-28-2003 02:09 AM
