Old 09-16-2004, 03:08 PM   #16
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
sorry, i thought the hole was stripped out at first. dont worry about a screw extractor, you will buy it and probably never use it again. just use the dremel to cut a slot it the screw and then use a slot screwdriver to take it out.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 09-17-2004, 06:34 AM   #17
ntc3freak's Avatar
thanks.but i am curious.have u guys ever done it and is it hard?
ntc3freak is offline   Reply With Quote
Old 09-19-2004, 12:53 PM   #18
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Originally posted by Rapid Roy
If its only one of the screws, you can remove the other 3, then rotate the engine while you use a screwdriver to hold the stripped screw. You won't need much force to hold the screw since you are turning the other end. I have done this many times. Works great.
same here.....
turn the engine around....
mop
mop_iko is offline   Reply With Quote
Old 09-19-2004, 08:04 PM   #19
ntc3freak's Avatar
but do you still have to slot the screw with a dremel so u can insert a screwdriver?how to turn the engine?
Old 09-20-2004, 10:45 AM   #20
Rapid Roy's Avatar
Remove all of the screws except the stripped one. Then just jamb a screwdriver into the screw and reach around and turn the engine. The screw will usually back right out. No need to slot the head.
Rapid Roy is offline   Reply With Quote
Old 09-20-2004, 10:47 AM   #21
mop_iko's Avatar
just make sure that your engine can make turns... not necessarily to make a FULL TURN... if you can turn your engine BIT by BIT and make sure the stripped screw is getting loose and loose....
usually you have to take out a lot of parts from the chasis in order to allow your engine to make turns....
i hope you understand and good luck dude!
mop
Old 09-20-2004, 06:54 PM   #22
JustRace's Avatar
mop
Get the screw extractor and do the job properly. It only takes a couple of minutes to drill the hole in the screw head. The amount of time it takes you to read this post you could pull out twenty stripped screw.
Order here http://doityourself.com/store/screwextractors.htm
or here
http://www.mytoolstore.com/kd/kdspec06.html
and read how it easy here
http://www.tpub.com/content/construc.../14256_151.htm
Now let's quit "screwing" around
JustRace is offline   Reply With Quote
Old 09-20-2004, 09:07 PM   #23
TheeMikeCee's Avatar
I got my black & decker dremel from wal-mart for $20. Its cordless and is great for the track. I never leave home without it.
TheeMikeCee is offline   Reply With Quote
Old 09-21-2004, 05:35 AM   #24
ntc3freak's Avatar
that cheap wa?my dremel lithium ion cordless rotary tool cost a hefty 70 usd
Urgent stripped screw help coons88 Electric On-Road 14 02-24-2007 04:46 AM
stripped pinion screw AZNracerx1989 Rookie Zone 3 08-02-2005 11:31 PM
Stripped Screw DIMO Electric On-Road 11 06-07-2005 03:57 PM
Stripped Screw RCDoon Electric On-Road 1 04-01-2003 09:11 AM
Stripped Screw Removal... skibum989 Electric On-Road 23 03-28-2003 02:09 AM
