Old 04-05-2011, 08:27 PM   #1
Trader Rating: 1 (67%+)
Default Putting a bump start motor into a Slayer Pro
How do I do this properly? I'm wanting to put a Mugen Ninja into my Slayer pro, I've already seen the traxxas big block kit to do so, but are there any other options after I get this kit as far as a clutch goes?
Will I be able to use a starter box to start my motor, if not what will I have to have in order to start the Mugen after I have installed it onto the slayer chassis?
And
Are there any other options for clutch systems other than the stock clutch kit that comes standard with the slayer? Are there any aluminum options or multiple shoe or is there anyone out there that know that will work with the big block conversion kit?
Post pics, send links, anything will help or if someone knows the answers to all of this and can call me that would be really damn helpful so I can just ask away before I try ordering things that aren't going to be what I'm expecting.
-Anthony (760)521-3977
Yokota is offline   Reply With Quote
Old 04-05-2011, 08:54 PM   #2
Suspended
Trader Rating: 202 (96%+)
you will need a revo bump box, and yes alot of 3 shoe clutches will work, make sure you get a 34mm or 36mm flywheel. your best bet would be to google your question, im sure there are specific forums/threads about this subject.
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 04-05-2011, 09:39 PM   #3
Thank you sir, I will pick up the big block conversion kit with that integy 3 shoe clutch and see how it goes. 34mm+ shouldn't be an issue at all.
-Anthony
