Old 05-03-2002, 10:32 PM   #1
kitracer's Avatar
Default 2nd gear motor pinion on V-ONE-R
22 teeth pinion have the same diameter as pinion 21 and same dia as 20 teeth on the V-One -R.
Kyosho said the advantage is u don't need to space the engine to accommondate different pinion's size. However this is my questions -
If they are the same diameter on all the second gear's pinion, don't they travel the same distance per Rev .!!!! Need help.
then using 20 or 22 teeth would be the same speed
kitracer is offline   Reply With Quote
Old 05-03-2002, 10:36 PM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: 2nd gear motor pinion on V-ONE-R
you should work on ratio rather then roll out !! roll out is the tire size only !
Manticore is offline   Reply With Quote
Old 05-04-2002, 07:40 AM   #3
Mauler's Avatar
Send a message via ICQ to Mauler
It is right if you are using a flat belt and pulley system. That's when the diameter is used to calculate the ratio. But we're using gears here, and the number of teeth is of concern, not the diameter...
Mauler is offline   Reply With Quote
Old 05-05-2002, 08:25 PM   #4
kitracer's Avatar
thanks for the input
But Kyosho made more teeth on the same pinion just
with finer pitch.
Is 64 pitch 30 teeth quicker than a 48 pitch 29 teeth engine [email protected]@@
I will make some track testing next week to see
tks again
Chris
Help super gear and pinion gear jojo RRR Electric On-Road 0 06-18-2007 07:37 PM
Would switching from a 19t pinion gear to a 21t pinion make a big difference ? thahookup Rookie Zone 5 05-19-2006 01:09 PM
tc3, rc10gt, losi, assoc, 48p and 64p pinion gear sets, orion rev motor islandRC R/C Items: For Sale/Trade 19 04-06-2005 01:01 PM
starter box motor pinion gear Franky Nitro On-Road 3 10-06-2003 03:36 PM
pinion gear yrless Electric Off-Road 1 03-23-2003 05:46 AM
