Old 09-05-2004, 12:44 PM   #1
New_Toasted's Avatar
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
Default End-Play on a Centax 1 clutch?
Hi!
I just wanted to know what would be a normal end-play setting for the first generation Centax from serpent, I mean, how many millimeters shall you be able to pull the clutch-bell out?
Thanks!
New_Toasted is offline   Reply With Quote
Old 09-05-2004, 03:33 PM   #2
tazman34685's Avatar
Default End Play for Serpent Centrax
0.5-0.9 mm of end-play
Note: 0.6 mm is Ideal
tazman34685 is offline   Reply With Quote
Old 09-05-2004, 11:25 PM   #3
OK, Thanks!
Old 09-05-2004, 11:42 PM   #4
InitialD's Avatar
Just a note. Clutch gap and end play are two different things.
By definition, end play should be most mininum (about 0.1 mm or so) and clutch gap should be about 0.3 to 0.7 mm. Bigger gap for more agressive engagement and small gap for smoother engagement.
Refer to Glenn Cauley's article on mytsn on how to set the Centax 1 clutch properly.
http://www.mytsn.com/publ/publ.asp?pid=10532
Old 09-06-2004, 10:29 AM   #5
Thanks for the great link! Now I'm going straight down to set-up my Centax properly
CENTAX CLUTCH Nikonianmike Nitro On-Road 5 08-31-2008 06:51 PM
clutch play dido41 Rookie Zone 0 08-02-2006 05:33 PM
Centax Clutch Bnw Rookie Zone 1 07-26-2005 03:20 AM
Centax clutch?? NightLife Nitro On-Road 3 07-26-2003 12:08 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 05:01 PM
